How to run PMIX35 software under windows / ultimate
arjanm
Re: How to run PMIX35 software under windows / ultimate
Post by arjanm »
PMIX35 works fine for me for years already, some notes:
- Use driver 6.6.1 (instead of 4.4 I saw mentioned above)
- When trying to send a command and seeing the led blink, but the device is not affected, often this is a issue around voltage.
PMIX35 does reset the voltage level to 0 sometimes when power is lost. Manually set the voltage to 5 volt solves this issue.
- Missing packets with the PMIX35 should not be possible because the buffer is caching all incoming signals.
Make sure the buffer is not full by setting the poll time correctly.
rances
Post by rances »
Does anyone still have has the x64 driver to share?
arjanm
Post by arjanm »
rances wrote: Wed May 17, 2023 9:18 am Does anyone still have has the x64 driver to share?
Yes, I have uploaded the driver here: https://filebin.net/g9116o9lukjxv8b8
rances
Post by rances »
Hi Arjan, is this link broken or it was valid for a limited time? I missed it. Would you mind uploading it again?
arjanm
Post by arjanm »
rances wrote: Thu May 25, 2023 9:56 pm Hi Arjan, is this link broken or it was valid for a limited time? I missed it. Would you mind uploading it again?
The filebin expires in 6 days. This is a new upload: https://filebin.net/vk0y5gdkk6odiwd2
Snirp
Post by Snirp »
Does anyone still has the PMIX35 software? Trying to find it somewhere but all the links are no longer working.
arjanm
Post by arjanm »
Snirp wrote: Fri Nov 10, 2023 3:00 pm Does anyone still has the PMIX35 software? Trying to find it somewhere but all the links are no longer working.
I uploaded it again: https://filebin.net/hdc9o0179rndjxjs/PMIX35.zip
Are you guys still using the PMIX35?
