Firmware update HCB
Marank08
Firmware update HCB
Post by Marank08 »
does annyone knows how i can update HCB firmware 1.0 to 1.6
when i tried to update to 1.6 i get an error
Thanks
Re: Firmware update HCB
Hi Marank08,
Maybe it's a good thing to tell a bit more, cause now the 1st question that you'll get will be: "what error ?"
Other members can't help you this way.
Marank08
Post by Marank08 »
the error is:
http error in http eval of config_upgrade_file.pl: Global symbol "$substr" requires explicit package name at (eval 16049) line 135, line 193. syntax error at (eval 16049) line 135, near "$substr("
i get this error when i try to load this file: firmware-eh_1.6.0-1026
Gr
speedtriple
Post by speedtriple »
Hi Marank08,
Did you succeeded in installing the firmware, if not I have still the previous version HCB_firmware_eh_1.6.0_1025.zip, maybe this one works fine.
Ties
Post by Ties »
does annyone knows how i can update HCB 1.2.258 to -eh_1.6.0-1026.hcb
when i tried to update to 1.6 i get next error: Fout: het upgrade pakket heeft een ongeldig formaat. Controleer of u het juiste bestand heeft en probeer opnieuw (package.xml parse error)
Thanks
Henk
Post by Henk »
Upgrading first to 1.4 is required and finally to 1.6 .. so try to find HCB 1.4 maybe marmitek ? Henk
Ierlandfan
Post by Ierlandfan »
Has anyone saved 1.6.0-1026.hcb? I can't find it these days anymore.
