Marmitek sensors ms13 doesn't connect to control unit SC9000
Frankge973
Post by Frankge973 »
I bought a second hand control alarm unit Sc9000 plus PIR four sensors, two ms13 and two ms90. Ms13 sensors doesn't register in control unit when I set it up using install area of menu. One ms90 is working perfectly, one is working but only in repetitive detection mode, even if I change the selector on the rear.
In your opinion, why they don't register ?
Thanks
mbliek
Re: Marmitek sensors ms13 doesn't connect to control unit SC9000
Post by mbliek »
The ms13 is not an supported motion sensor for the sc9000. Only the ms90
Frankge973
And do you think is possible to use also sensors of other brands? Or I'm obliged only to use ms90?
mbliek
Post by mbliek »
The ms90 is also available from other brands. But it's the same.
But only the ms90 will work
Frankge973
And which cheaper brand and model can I buy?
