Devices depart from the 1 Wire network unexepected
Forum about 1-Wire devices.
Postby Curtain » Sun Sep 21, 2008 9:02 pm
I've recently bought a master hub from hobby boards for one wire and after a few hours running, the device
(I have only one, the battery monitor) departs from the network unexpectedly.
Also, I see that the switches in the hub itself depart from the network.
I am using the Java API, and RXTX on Linux.
Every now and then, I get the following exceptions:
Exception: com.dalsemi.onewire.adapter.OneWireIOException: OneWireContainer26-Bad CRC during read.99
Exception: com.dalsemi.onewire.adapter.OneWireIOException: OneWireContainer1F verify on command incorrect
Please advise.
Best regards,
-- Jaap Gordijn
Curtain
Postby Digit » Sun Sep 21, 2008 9:45 pm
I could advise you to buy a HA7Net, but i don't know if that will work in your situation and if it's the answer you're looking for... have you tried [url="http://www.cocoontech.com/index.php?showforum=41"]this[/url] forum?
Postby Curtain » Tue Sep 23, 2008 2:09 pm
Thanks.
As it seems right now, the problem is caused by the USB to serial adapter.
If this adapter is behind an USB 2.0 hub, it causes problems on Linux.
Curtain
Return to 1-Wire Forum
cron
