1-wire Ph sensor
Forum about 1-Wire devices.
endre
1-wire Ph sensor
Post by endre »
Hello.
I'm trying to use a 1-wire device to monitor my aquarium. One of the things I want to monitor is the pH.
Is there a pH-probe or sensor that I can connect to the 1-wire?
Or some other way of doing this?
Endre
1-wire Ph sensor
Endre
Check the site of 1-wire Dallas semiconductor http://www.maxim-ic.com/ You can search the site on "PH Sensor".
Here is also a discussion going on about a 1-wire PH sensor but it is in French! (browse half way the discussion)http://groups.google.nl/group/fr.sci.el ... t&q=1-wire
Hope this helps
Regards Pieter
Return to “1-Wire Forum”
