Connecting Honeywell humidity sensor
Forum about 1-Wire devices.
Postby yhan » Sun Apr 08, 2012 2:00 pm
Hi 1-wire experts
I have a question for you guys : does anyone in the forum successfully setup a HIH-4021 (Humidity sensor from Honeywell) and a DS2438 ?
I have been told the only way to make work the HIH-4021 is to use a DS2438, so I'm looking for a way to connect it to the 1-wire bus.
Could anyone link me to a connection diagram or something ?
Thanks !!
-Yhan
yhan
Re: Connecting Honeywell humidity sensor
Postby Digit » Sun Apr 08, 2012 6:34 pm
Is there nothing to tell about the HIH-4021?
Postby yhan » Sat Apr 14, 2012 1:54 pm
Sure
This is a humidity sensor, made my Honeywell, my understanding is the probe is analog.
The sensor has 3 pins, + Ve (Supply Voltage 5v DC), OUT (Voltage OUT), and - Ve. The specs are fully detailed in that PDF (http://midondesign.com/Documents/HIH4021.pdf).
To make it work with the 1-Wire bus, I have told to use a DS2438, how should I connect to the DS2438 ?
Datasheet of the DS2438 can be found here : http://pdf1.alldatasheet.net/datasheet- ... S2438.html
Ok from the HIH4021 to the DS2438 :
OUT to Vsens +
-Ve to Vsens -
+Ve to Vad
Would it work that way ?
Thanks !
yhan
Return to 1-Wire Forum
cron
