1 Wire send from arduino with 433Mhz
Posted: Tue Oct 01, 2013 8:06 pm
by Dylantje
Like the head says...
Is this possible.
I hav on my 3th floor morethings that i will monitor with 1 wire. [ solarpanels, inverter, hot watertank on solar, temp Cv etc..]
Only my RPi with Domoticz is on the other side of my house,
Is there a option that i use a arduino as a satellier ot node ?
All my 1 wire sensors to the arduino.
A 433Mhz Transmitter on the arduino..
One powersupply....
Search the arduino in Domoticz,with the RFXcom, and i have more 1 wire's that i can see in the dashbord...
Is this possible??
Some one have this working al ready?
Sketch?
Maybe a BMP085 on it to?
Re: 1 Wire send from arduino with 433Mhz
Posted: Tue Oct 01, 2013 11:41 pm
Arduino & 1-Wire is a breeze. I've used DS1820 temperature sensors & JeeNodes (Arduino compatible but doesn't work with shields, but can run battery powered) to measure all in- and outgoing water temperatures of our central heating radiators.
But Arduino & RFXCOM is another ball game - I don't even know if it has ever been done.
BMP085 is not that hard;done that.
http://blog.hekkers.net/2010/01/30/wire ... t-results/
Posted: Thu Oct 03, 2013 7:12 pm
by Dylantje
I was thinking that would be great a satelliet sensor.
And there must be more options with teh arduino, for a 433Mhz transmitter.
The mega works with more hardware.
Maybe there is some where a arduino project what like for idea.
Only i connot find id.
Posted: Sun Jan 19, 2014 4:36 pm
by Hendrik
when you have a rfxtrx 433 mhz, you can use a rfxsensor like this http://www.rfxcom.com/store/Sensors/40066
you can use 7 sensors, and it works great
Posted: Sun Jan 19, 2014 11:42 pm
by Dylantje
Where to buy in. Holland
Posted: Mon Jan 20, 2014 6:38 pm
by Hendrik
you can try sensing an email to rfxcom, maybay they have one
Posted: Sun May 11, 2014 2:55 pm
by bengt
Hi Dylantje,
How did it go with this project?
I'm starting to play with my RFXtrx433/Domoticz, and would like to create my own sensors for sound (washing machine finishes with a beep) and plant soil humidity alarm (since I can't seem to find any ready sensors for a reasonable price). It seems perhaps the Arduino UNO R3 might a good solution for this. Provided that it can transmit to the RFXtrx433...
So I am very curious in hearing if you have come any further on this?
