Bwired Googlemaps upload data webservice
Re: Bwired Googlemaps upload data webservice
Postby ludom » Tue Aug 28, 2012 8:22 am
Hmm, OK.
Isn't it weird that you have 33 Geeks online on the map now, when the last week(s) this was around 40 geeks?
Home-brewed HA system based on Linux, PHP5, MySQL and Beanstalkd
ludom
Postby Bwired » Tue Aug 28, 2012 1:45 pm
I cleaned the user database
Most users have a very solid system and updating every hour
when I see that a user does not update anymore for a longer time i disable the account
Otherwise its showing old data.
Postby ludom » Tue Aug 28, 2012 2:10 pm
Ok, that make sense.
ludom
Postby appie » Tue Aug 28, 2012 5:39 pm
Ludom,
Thanks, this is working perfect.
Do you have a idea for a blank line, just to make groups for the sensor data in the Google screen?
My idea is not working, and I can’t find the right code for this with the addEntry?
$bwired->addEntry('  ', 7, '  ', NULL);
Albert
appie
Postby Bwired » Tue Aug 28, 2012 10:46 pm
You mean a blank line between the existing data? (so in the xml)
If so that wont work i guess, prog checks on data etc.
Postby appie » Thu Aug 30, 2012 5:30 pm
Ok, that’s a pity. I think this will make reading the sensor data a little bit easier. But if it isn’t possible, this will go over.
Thanks
Albert
appie
Postby 123unlock » Tue Mar 04, 2014 2:02 pm
Hi Pieter,
I just uploaded an XML to your service, can you check if the data is correct
Xtrusion Digital Home Automation Project
123unlock
Postby Bwired » Tue Mar 04, 2014 11:41 pm
Will check later, not at home this week
Postby Bwired » Sat Mar 08, 2014 10:44 pm
123unlock wrote:Hi Pieter,
You are added to the upload
thanks!
Postby 123unlock » Sun Mar 09, 2014 8:17 am
Cool.. i just check it but didnt found it on the map yet. Is there some delay before its visible ?
123unlock
Postby Bwired » Sun Mar 09, 2014 11:44 am
i think i found the problem
<Value>8.5 ℃</Value>
loose the ℃ its in the units
btw: i will rewrite Bwired googlemaps this soon with Node.js
Postby esschenk » Thu Mar 05, 2015 6:08 pm
Is there any change that this is converted to HS3
Ed.
esschenk
Postby DJF3 » Sun Oct 11, 2015 9:19 pm
esschenk wrote:Hello,
Ed
+1
DJF3
Previous
Return to Bwired Forum
cron
