I would like to add some weather data to HSTouch (HS3) but cannot find the right plugin for the job. I want the data to be applicable for my City and thought about getting it using the internet until i get my own weather station which could take a while . I already found plugins like Jon00 BBC Weather and Jon00 RSS feedviewer but BBC only supports some dutch locations. And the RSS feeds of KNMI is limited
I found out that i can actually use RSS feed in HSTouch and it seems to be the way to go. But how do i get http://xml.buienradar.nl <weerstation id="6278"> in a text field on HSTouch ?
Weather data in HSTouch
Re: Weather data in HSTouch
This how i do this kind of display. Usualy i have this data already stored in a device in HS, so HS is collecting the data. I put that device then onscreen in HSTouch. It will reduce the load also.
