Fibaro modules geven Device Unkown en Warnings bij toevoegen
Postby fabian » Sun Oct 02, 2016 3:19 pm
Sinds kort heb ik een aantal Fibaro modules toegevoegd aan mijn HS3 installatie. Wat opvalt is dat bij het toevoegen van een node Homeseer al een Warning geeft. Dit heb ik zowel bij de Aeon Labs usb stick als die van Zwave-Me. De warning verschilt wel.
Getting Z-Wave Plus Association Group Information (5 groups) from Node 2...
Z-Wave Plus Association Root Group Information For Group 5 retrieved successfully from Node 2 Group Name=Dimmer(S2), Profile Is General:Reserved And the group hosts 1 Event commands.
Warning: Node 2, EndPoint=1 Multilevel Sensor Report was not received (B) - the child device will NOT be configured properly.
Warning: Node 2 did not respond to the Notification Supported request.
Root Node Device Node 2 Z-Wave Fibaro Switch Multilevel was created for node 2 on network F64D0BF5
Z-Wave Me: Adding association for Z-Wave device Node 2 Z-Wave Fibaro Switch Multilevel (Node 2, Group 1, Endpoint 1) to HomeSeer
Z-Wave Me: Adding association for Z-Wave device Node 2 Z-Wave Fibaro Switch Multilevel (Node 2, Group 2, Endpoint 2) to HomeSeer
Getting Z-Wave Plus Association Group Information (5 groups) from Node 14...
Z-Wave Plus Association Root Group Information For Group 3 retrieved successfully from Node 14 Group Name=Dimmer(S1), Profile Is General:Reserved And the group hosts 1 Event commands.
Z-Wave Plus Association Root Group Information For Group 4 retrieved successfully from Node 14 Group Name=On/Off(S2), Profile Is General:Reserved And the group hosts 1 Event commands.
Z-Wave Plus Association Root Group Information For Group 5 retrieved successfully from Node 14 Group Name=Dimmer(S2), Profile Is General:Reserved And the group hosts 1 Event commands.
Warning: Node 14, EndPoint=1 Multilevel Sensor Report was not received (B) - the child device will NOT be configured properly.
Warning: Node 14 did not respond to the Notification Supported request.
Root Node Device Node 14 Z-Wave Fibaro Switch Multilevel was created for node 14 on network E86BE373
Aeon Labs: Adding association for Z-Wave device Node 14 Z-Wave Fibaro Switch Multilevel (Node 14, Group 1, Endpoint 1) to HomeSeer
Aeon Labs: Adding association for Z-Wave device Node 14 Z-Wave Fibaro Switch Multilevel (Node 14, Group 2, Endpoint 2) to HomeSeer
Wanneer ik de fibaro module bedien (lokaal of via HS3) dan veranderd de waarde in Unkown.
Stukje log
okt-02 16:14:20         Change    Node 14 Z-Wave Switch Multilevel 2 changed from 99 to 99 (E86BE373-014-Q109)
okt-02 16:14:20         Z-Wave    Device: Node 14 Z-Wave Switch Multilevel 2 Set to INVALID VALUE
okt-02 16:14:20         Z-Wave    ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_MULTI_CHANNEL_V2 Frame(7)=13
okt-02 16:14:20         Z-Wave    ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
okt-02 16:14:20         Z-Wave    Aeon Labs: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY
okt-02 16:14:20         Z-Wave    ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64
okt-02 16:14:19         Change    Node 14 Z-Wave Switch Multilevel 2 changed from 0 to 99 (E86BE373-014-Q109)
okt-02 16:14:19         Z-Wave    ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
okt-02 16:14:18         Z-Wave    Aeon Labs: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY
okt-02 16:14:18         Z-Wave    Aeon Labs: Sending to node 14 (Secure) CC=COMMAND_CLASS_MULTI_CHANNEL_V2
okt-02 16:14:18         Device Control    Device: Node 14 Z-Wave Switch Multilevel 2 to On (99) by/from: CAPI Control Handler
Moet ik na het simpelweg toevoegen van een Node nog iets doen aan de settings om alles goed te laten werken ?
fabian
Re: Fibaro modules geven Device Unkown en Warnings bij toevoegen
Postby Akatar » Sun Oct 02, 2016 4:15 pm
wat voor modules?
kan zijn dat je moet kiezen voor secrured inclusion, en dan dicht bij de stick toevoegen
Akatar
Postby fabian » Sun Oct 02, 2016 4:48 pm
FGD-212 (Dimmer 2)
Ik gebruik in HS3 de 'Add/Include a node' optie. Er staat ook een 'Add/Include a node non secure' onder, waardoor ik er vanuit ga dat de eerste optie juist wel secure is.
Er zit nu zo'n 40cm hemelsbreed tussen de Zwave-Me USB dongle en de dimmer.
fabian
Postby fabian » Sun Oct 02, 2016 5:05 pm
Wanneer ik een node include 'non secure' dan blijft HS3 herhalen: " Activate the 'Add to Network' function on the device..." Ververs ik ondertussen de nodes dan zie ik er wel een bij gekomen, maar wordt dus niet goed geinclude. Geen device aangemaakt in HS3.
Als testje ook nog een module ver weg gelegd en vervolgens proberen te leren. Dan krijg ik
Add Node started...
A new node is being added...
Adding a new SLAVE NODE...
DONE - Add Node Operation is Complete.
Done. Node 8 Added.
Reloading (importing) node information...
Synchronizing node information with HomeSeer and creating new device(s) as necessary...
Synchronize nodes finished. Number of device nodes to be created/added = 1
Z-Wave manufacturer information for node 8, ID: 271=10FH (Fibaro), Type: 258=102H, ID: 4096=1000H
Negotiating or Verifying SECURITY SCHEME for node 8
Warning: Failed to get a SECURITY SCHEME or verify the key from node 8. Device may not be added properly to HomeSeer.
Warning: The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)
Warning: If this device was previously added to the network, the device may need to be removed from the network and re-added.
Warning: In case the device was previously added successfully, an attempt will be made to continue the import.
Getting SECURITY class information for node 8
Error: Security class information is NOT present - cannot continue loading node 8
Warning: The device at node 8 should result in 5 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
Finished.
fabian
Postby Akatar » Sun Oct 02, 2016 5:39 pm
volgens mij staat er ook op het homeseer forum vermeld dat er problemen waren/zijn
ik kreeg hem toen de dimmer2 uitkwam niet goed aan de praat met hs3.
misschien dat er inmiddels updates zijn voor hs3? iig wel voor de dimmer 2, laatste versie is 3.4
voor het updaten heb je iemand nodig met een homecenter
Akatar
