Hi All,
In the Netherlands a subsidy is available if you install a heat pump. As I allready use Homeseer to control some parts of the house I also want to control the heat pump using Homeseer. Has anybody experience with controlling a heat pump using HomeSeer?
John
controlling heat pump using HomeSeer
Re: controlling heat pump using HomeSeer
Hi John,
How are you doing with you project?
I'm having an Toshiba ras-b13skvp that I control with homeseer and ir-trans.
Kind regards,
Leo
Kind regards,
Leo
