Installed registered version of plugin Ultra1Wire2 (1.0.4009.16700) and HA7Net.
(Windows 7 and Homeseer Pro version 2.5.0.1 ).
Now its realy hot in Drenthe, the temperature (Celcius) in the HS-homepage is 205625 in stead of 20,6 degrees.
And (I think the same problem) in the vertical scale in the Charts is 225 in stead of 22,5 degrees.
See attachments.
I can't find settings in the Options-page.
Anybody solved this problem?
THANKS, Verkenner
Temperature in HS Ultra1wire2 plugin
Moderator: Ruud
- Temperature in HS-homepage
- homepage.JPG (26.74 KiB) Viewed 2740 times
- Ultra1wire2 Chart
- graphic.JPG (38.49 KiB) Viewed 2740 times
- Options page ultra1wire2
- options.JPG (90.14 KiB) Viewed 2740 times
Best regards, Verkenner
SOLVED Temperature in Ultra1wire2 plugin
Ultrajones solved the problem in Ultra1wire2.
Found in board.homeseer.com/showthread.php?p=958 ... post958889
Now Ultra1wire2 (version 1.0.4046.35518, now in HS-updater) in the Europe-region is working great.
Re: Temperature in HS Ultra1wire2 plugin
problem was known for months, ultrajones never updated the plugin (solved the problem)
PI Ultra1wire2 plugin 100%
Now HS PI Ultra1wire2 works like a charme.
Tip: Do not foget to set the jumpers in the HA7Net
Regards Verkenner
Regards Verkenner
- 1-wire.JPG (90.4 KiB) Viewed 2691 times
