today i got a remotec remote. after i had big problems with Klik aan uit remotes of double triggering
now i want to use it with homeseer,i know that it can be used secondary controller but i don't how
and how wil HS see this device?? and will i be able to control events?
Remotec remote as secondary controller in hs
Re: Remotec remote as secondary controller in hs
HS can't see the device.
You can only use as secondary controller for you zwave devices.
Just set de remote in receive mode
from homeseer replicate send.
or just click the USB stick for sending the data.
can i not control one sene with hs because the remote must see it as one node?
so hs must see one switch op not?
Ralph
HS and remote can control devices.
You can't run HS events from the remote..both direct scene control is possible from the remote.
