Homeseer /Danfoss RA radiator valves
Postby Fischi » Sun Sep 30, 2012 5:46 pm
does anybody use Danfoss RA radiator valves in Homeseer, if yes, where to buy the ("old") RA-thermostats ?
Does it work perfect ?
HS screenshots aviable ?
Regards, Fischi
Fischi
Re: Homeseer /Danfoss RA radiator valves
Postby krizzz » Mon Oct 01, 2012 9:17 pm
Good post! Winter is coming and i an curious if Homeseer worked
out their problems with Danfoss!
krizzz
Postby keeslamper » Fri Oct 05, 2012 6:56 pm
I've two of the 'old' ones but can't use because my radiators use on/off buttons no thermostatic...
keeslamper
Postby TANE » Sat Oct 06, 2012 12:52 pm
The old ones works fine in Homeseer.
Don't forget to optimize the network manually with battery powered devices.
Off (moon)
Thermostat Value Set set to Permanent Setback On
On (Son)
Thermostat Climate Control Schedule Value Set set to Setback Off
The On/Off can be a bit confusing.
Best is to create a event and just simple use Off or On with the values above,
Postby abl » Sat Oct 06, 2012 1:24 pm
If somebody is interested, I still have two of them laying somewhere in my domotica stock (never installled)...
abl
Postby Reemster » Mon Nov 19, 2012 10:16 pm
Weet iemand waar ik deze 'oude' radiator kranen nog te verkrijgen zijn? .. neem aan dat er nog geen alternatieve radiatorkranen zijn die werken met homeseer?
Reemster
Postby keeslamper » Mon Nov 19, 2012 10:31 pm
Ik heb er twee liggen.
keeslamper
Postby mschut » Tue Nov 20, 2012 12:46 am
Kees, wat vraag je voor je 2 kranen? Heb wellicht interssen om e.e.a. eens te proberen...
Synology DS213+ / Domoticz / RFX Transceiver-e
mschut
Postby krizzz » Tue Nov 20, 2012 10:31 am
Just to be clear... The Old "valves" only work with an On and Off function, correct? They do not adjust to a certain temperature? The sun and moon function is not totally clear to me...
krizzz
