I have an IPAD but when i want it to connect to HSTouch or the HomeSeer webinterface it is not working. It has worked in the past but it seems like the ipad is sending garbage so the HS server is not responding
They are on the same network and when i use my Android phone it is working fine
I just found out that when using https the ipad loads more page detail but it is very very slow and also mot working as it should
HomeSeer webpage and HSTouch not working on IPAD
Re: HomeSeer webpage and HSTouch not working on IPAD
It's only to homeseer/hstouch? other webpages (with https) loading normal?
Maybe it helps to switch off the ipad completly (press side button for several seconds and swipe to switch off).
Otherwise a reset to default settings?
it is only the hs website / hstouch
Perhaps helps this: If you're in the webbrowser, typ your ip adress with the portnumber behind it. Like 172.16.0.100:80
