Tonight is the second time i noticed that HS2 stopped running scripts. Switching on and off is working fine, but there are not scripts running at all.
Has anyone else had this problem in the past ?
HSPRO(2) Stops running scipts
Re: HSPRO(2) Stops running scipts
I had it once. It was because the virus scanner engine updated and it did a start of each program/script in a sandbox enviroment
The only thing that is running virusscan wise is "Windows Defender" this evening the problem is back again. HomeSeer is running fine but not running scripts/events or polling Z-wave status
The latest log entry
The only thing changed last couple of days are the windows updates
10-12-2013 15:24:12 ~!~Warning~!~Removing delayed event that did not get run perhaps due to HomeSeer being shut down: Delayed Actions:OT Gateway PR commands (delayed event)
Oke, some 'wild' thought about this
The scripts en events have a few extra options on the advance screen
Have a look at the checkboxes
- Allow only one instance of this script to run at once.
- Wait for the script to end.
Another thing that can flood your HS work queue is rapid firing events thus filling up the queue and halt the processing in HS.
Have a look at the 'can't retrigger in X seconds" option
I killed HS once professionally by setting a trigger at Full moon on an event.
It really worked. The day that it became full moon the event started to trigger and trigger and trigger and....
