stupid...but am asking anyway
Moderator: b_weijenberg
nawikre
Post by nawikre »
Hi guys,
i have not worked with rfxcom in a while...because everything just works....I just bought those perfect oregon thgr238 sensors and want them implemented in homeseer.
I added these without any problem in the input devices, but i forgot how to get them on the status page displaying the humidity and temperture.
I already read the rfxcom manual item 7 ....but this is what it says...
7. Configure devices in Homeseer
7.1. Add an Oregon sensor
• Go to the RFXCOM Input Dev. Configuration page and click Clear Heard.
• Select the channel (if appropriate) on the Oregon sensor.
• Insert the battery in the Oregon sensor.
• Wait until the sensor has sent an RF packet. (normally a few seconds after battery inserted or
after a sensor reset)
• Click ADD on the RFXCOM Input Dev. Configuration page and add the Oregon sensor(s)
found.
But what now....i am a bit stuck
greetz,
Iwan
b_weijenberg
Re: stupid...but am asking anyway
Post by b_weijenberg »
Sensors you add appear on the Status page (if the sensor is not hidden, which is true for the battery sensor)
nawikre
Post by nawikre »
they where indeed hidden, but i can only see the humidity...not the temperture....How is that?
greetz,
Iwan
xanhoera
Post by xanhoera »
nawikre wrote:they where indeed hidden, but i can only see the humidity...not the temperture....How is that?
I guess you'll need to add a device for each: L, T and H :-)
