I am able to control my home LED lighting with a 24 (6x4digits) digit pulse in the RFXcom mgr via lighting 4.
I am not able to find how to do this via homeseer. Is the same lighting4 functionality enabled in the HS3 plug-in? And if yes how do I use this? (How do I sent these 24 digit commands)
Thx,
Rob
Rfxcom homeseer plug-in and lighting4
- b_weijenberg
Re: Rfxcom homeseer plug-in and lighting4
See chapter 11.6 in the RFXCOM HS3 User Guide.pdf
Can you please tell me where I can find the HS3 RFXcom user guide (can only find the hs2 guide on Rfxcom page).
I cannot find it anywhere on the homeseer pages or on the rfxcom page. In the homeseer forum you refer to the homseer documentation page. But it is not there (at least not under help / documentation).
Thx for your help.
Thx for your help.
- b_weijenberg
This document is in the Homeseer3 Docs directory (after the plug-in is installed)
Ok, thx found it.
I was looking on the homeseer side / rfxcom side. Didn't think about my own homeseer 3 drectory. You mentioning the plug-in did the trick.
Thanks for pointing me in the correct direction....now its clear (also chapter 11.6 )
Thx,
Rob
Thx,
Rob
