RFXmeter for measuring waterusage
Postby abl » Sat Jun 20, 2015 10:32 pm
Since a short while, I'm the owner of a RFXmeter with three modules (thanks Bert for helping me out). I've succeeded to calibrate the gasusage and to link it to Homeseer.
To measure my waterusage I apparantly need a reed-relais. I've got the same PIDPA watermeter as depicted on this website: http://www.domoticaworld.com/projects/monitor-water/. Could someone help me as to which reed-relais I should buy and how I should connect this physically to the watermeter as well as to the rfxmeter?
abl
Re: RFXmeter meten waterverbruik
Postby vincenttor » Sun Jun 21, 2015 9:14 am
ill pm it. didnt pay attention it was in english
vincenttor
Re: RFXmeter for measuring waterusage
Postby abl » Sun Jun 21, 2015 6:18 pm
Thanks Vincent for giving me some background. Would this Conrad reed relais be what I need?
conrad.be/ce/nl/product/502036/PIC-PRX1 ... -50-mA-1-W
abl
Postby vincenttor » Sun Jun 21, 2015 7:36 pm
Thats to expensive.
How fast do you want this sensor, do you have the patience to wait 1 - 3 maybe 4 weeks ?
and its even cheaper when you buy like in the url you gave a Klik aan klik uit deur sensor.
That contains a small glass tube reed switch that should also work.
here you have some cheaper ones, not sure if you need NO or NC but i think its NO.
http://www.aliexpress.com/item/Differen ... 02038.html
Also on ebay you can find these and others.
vincenttor
Postby abl » Tue Jun 23, 2015 9:22 pm
As with all gadgets, preferably yesterday :-)
Besides the price, would the conrad reed relay be the right one (as it is already finished for my type of electronics knowledge)...
abl
Postby vincenttor » Tue Jun 23, 2015 9:38 pm
i think it should work yes but its a expensive gamble , t be 100% sure you can better ask Bert for confirmation but i'd say yes it should do the trick.
vincenttor
Postby abl » Tue Jun 23, 2015 10:11 pm
Thanks for your help.
Needed to order several things at Conrad, so thought would give it a try.
abl
Postby abl » Sat Jun 27, 2015 5:53 pm
I received the Reed Relay today but wonder how I should connect this to the jack plug. There is a blue and a yellow wire on the relay and if I read the manual of RFXcom I should connect these to pin 2 and 3 of the jack plug. Some questions I have:
- Should these be soldered or can I just wire these?
- To what connectors on the jack plug should these be linked?
abl
Postby Mai Pensato » Sat Feb 20, 2016 11:53 pm
Recently I could buy a second hand RFXmeter with RFXpulse and a reflective-optical sensor. Goal is to read out my water meter which is a Itron Aquadis+ with a spinning wheel that is partly red and partly silvergrey. After some trial and error: placing the sensor on the right place and taping it very well and playing with the potentiometers P! and P2 on the RFXpuls I have got it working. Although there is a slight difference between the liters/pulses via the RFXmeter compared to the Itron meter itself. The RFX gives approximately 1% too much liters. This is after monitoring this very close for a week.
Is it possible to get this better, if yes: how ?? Has anyone got this working reliable over a long period of time?
Alternative solution is to use a "Cyble sensor"" that is made for the Itron Aquadis meter. But this sensor cost 70-80 EUR. Anyone experience with this sensor ? Does this work 100% reliable ?
Any advice on getting more reliable measurements is very welcome !
Mai Pensato
Return to Rfxcom Receivers & Transmitters Forum
cron
