Team,
When I look at the data coming from my RFXMeter in HS3, you see there's many gaps.. Gaps where no data is received.
Q: Any idea why this happens and troubleshooting tips?
Is it RF transmission issues? An issue with the RFXCOM lan?
Here's some sample data:
……………… POWER GAS WATER
02-Feb 00:00:05 46,021 175,061 260,647
02-Feb 01:00:04 46,021 175,061 260,647
02-Feb 02:00:04 46,021 175,061 260,647
02-Feb 03:00:03 46,021 175,061 260,647
02-Feb 04:00:04 46,022 175,061 260,647
02-Feb 05:00:04 46,022 175,061 260,647
02-Feb 06:00:03 46,022 175,061 260,647
02-Feb 07:00:04 46,022 175,061 260,649
02-Feb 08:00:04 46,024 175,061 260,669
02-Feb 09:00:03 46,024 175,061 260,669
02-Feb 10:00:04 ........... ........... ...........
02-Feb 11:00:04 ........... ........... ...........
02-Feb 12:00:04 ........... ........... ...........
02-Feb 13:00:03 ........... ........... ...........
02-Feb 14:00:03 ........... ........... ...........
02-Feb 15:00:04 46,027 175,061 260,708
02-Feb 16:00:03 46,027 175,061 260,708
02-Feb 17:00:04 46,027 ........... 260,739
02-Feb 18:00:04 ........... ........... 260,739
02-Feb 19:00:03 ........... ........... ...........
02-Feb 20:00:04 ........... ........... ...........
02-Feb 21:00:03 ........... ........... ...........
02-Feb 22:00:04 ........... ........... ...........
02-Feb 23:00:04 ........... ........... ...........
03-Feb 00:00:06 ........... 175,061 ...........
03-Feb 00:00:07 ........... 175,061 ...........
03-Feb 01:00:04 ........... 175,061 ...........
03-Feb 02:00:03 ........... ........... ...........
03-Feb 03:00:03 ........... ........... ...........
03-Feb 04:00:04 ........... ........... ...........
03-Feb 05:00:04 ........... ........... ...........
03-Feb 06:00:04 ........... ........... ...........
03-Feb 07:00:04 ........... ........... ...........
03-Feb 08:00:04 ........... ........... ...........
03-Feb 09:00:04 ........... ........... ...........
03-Feb 10:00:04 ........... ........... ...........
03-Feb 11:00:04 ........... ........... ...........
03-Feb 12:00:04 ........... ........... ...........
03-Feb 13:00:04 46,043 ........... 260,945
03-Feb 14:00:04 46,046 175,061 261,007
03-Feb 15:00:04 46,046 175,061 261,031
03-Feb 16:00:05 46,051 175,061 261,031
03-Feb 17:00:04 46,051 175,061 261,031
03-Feb 18:00:04 46,051 175,061 261,058
03-Feb 19:00:04 ........... 175,061 261,058
03-Feb 20:00:04 ........... ........... ...........
03-Feb 21:00:04 ........... ........... ...........
03-Feb 22:00:05 ........... ........... ...........
03-Feb 23:00:03 ........... ........... ...........
04-Feb 00:00:04 ........... ........... ...........
04-Feb 01:00:03 ........... ........... ...........
04-Feb 02:00:04 ........... ........... ...........
04-Feb 03:00:03 ........... ........... ...........
04-Feb 04:00:04 ........... ........... ...........
04-Feb 05:00:04 ........... ........... ...........
04-Feb 06:00:04 ........... ........... ...........
04-Feb 07:00:04 ........... ........... ...........
04-Feb 08:00:04 ........... ........... ...........
04-Feb 09:00:03 ........... ........... ...........
04-Feb 10:00:03 ........... ........... ...........
04-Feb 11:00:03 ........... ........... ...........
04-Feb 12:00:04 ........... ........... ...........
04-Feb 13:00:04 ........... ........... ...........
04-Feb 14:00:03 ........... ........... ...........
04-Feb 15:00:03 ........... ........... ...........
04-Feb 16:00:04 ........... ........... ...........
04-Feb 17:00:03 ........... ........... ...........
04-Feb 18:00:03 ........... ........... ...........
04-Feb 19:00:03 ........... ........... ...........
04-Feb 20:00:04 ........... ........... ...........
04-Feb 21:00:04 ........... ........... ...........
04-Feb 22:00:04 ........... ........... ...........
04-Feb 23:00:04 ........... ........... ...........
05-Feb 00:00:04 ........... ........... ...........
05-Feb 01:00:03 ........... ........... ...........
05-Feb 02:00:04 ........... ........... ...........
05-Feb 03:00:03 ........... ........... ...........
05-Feb 04:00:03 ........... ........... ...........
05-Feb 05:00:04 ........... ........... ...........
05-Feb 06:00:04 ........... ........... ...........
05-Feb 07:00:04 ........... ........... ...........
05-Feb 08:00:04 ........... ........... ...........
05-Feb 09:00:04 ........... ........... ...........
05-Feb 10:00:03 46,088 175,061 261,300
05-Feb 11:00:03 46,088 175,061 261,314
05-Feb 12:00:04 46,089 175,061 261,318
05-Feb 13:00:03 46,089 175,061 261,318
05-Feb 14:00:04 46,089 175,061 261,326
05-Feb 15:00:04 46,090 175,061 261,326
05-Feb 16:00:04 46,090 175,061 261,339
05-Feb 17:00:03 46,091 175,061 261,346
05-Feb 18:00:04 46,091 175,061 261,346
05-Feb 19:00:03 46,091 175,061 261,346
05-Feb 20:00:03 ........... ........... ...........
05-Feb 21:00:03 ........... ........... ...........
05-Feb 22:00:04 ........... 175,061 ...........
05-Feb 23:00:04 ........... 175,061 ...........
RFXMeter - transmission problem?
Re: RFXMeter - transmission problem?
perhaps a oregon sensor with almost flat battery
Thanks for the tip..
ohw crap.. At any given time I seem to have at least 5 of them
So is there anything specific happening when these Oregon sensors run out of battery?
Yesterday morning I happen to blow up a Fibaro z-wave module that was sitting right next to the RFXCOM LAN..
The weird thing is that it seems (I repeat, seems) like "the numbers" are coming in without problems...
Hmm.. I'll continue to investigate and will replace batteries of empty Oregon sensors..
</dj>
</dj>
