[ser2net] RFXtrx433e is not working after reboot of HS3
Postby raymonvdm » Sat Dec 23, 2017 2:18 pm
Yesterday i rebooted the Winodws 10 PC running HS3 Pro (3.0.0.357 + RFXcom 30.0.0.35) but since the reboot my ser2net RFXcom is no longer working
22-12-2017 13:27:34 ~!~Info~!~Plugin RFXCOM has connected. IP:127.0.0.1:49975
22-12-2017 13:27:34 ~!~RFXCOM~!~35 (InitIO) RFXCOM version is:30.0.0.35
22-12-2017 13:27:35 ~!~RFXCOM~!~35 (InitTRX) Connect Transceiver #1  on COM9
22-12-2017 13:27:35 ~!~RFXCOM Error: ~!~35 (StartIO) transceiver 2 has no com interface configured!
I already upgraded to 30.0.0.36
I have restarted ser2net
Enable/Disabled the plugin
Note: The other RFXtrx433 which is connected by USB is working fine
Note2: I`m also running Domoticz and the ser2net setup is working fine (when HS3 is not running) So the ser2net machine or interface is not the issue
2017-12-23 14:21:01.307 RFXCOM: TCP/IP Worker stopped...
2017-12-23 14:21:04.380 RFXCOM: connected to: 192.168.110.244:10001
2017-12-23 14:21:04.976 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1001
Firmware type = Ext
Hardware version = 1.3
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
Conrad RSL disabled
ByronSX enabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
2017-12-23 14:23:00.047 (RFXtrx433e KMP1) Lighting 2 (Unknown)
2017-12-23 14:23:07.173 (RFXtrx433e KMP1) Lighting 2 (Unknown)
raymonvdm
Re: [ser2net] RFXtrx433e is not working after reboot of HS3
Postby raymonvdm » Sat Dec 23, 2017 2:32 pm
And now it is working....
Apparently the COM port = TCP/IP was not save correctly
raymonvdm
Return to Rfxcom Receivers & Transmitters Forum
cron
