With the modern (before wheels) KAKU modules you have to program each remote (transmitter) into the kaku modules. I'm switching from HS2 to HS3 building a 2nd system with a new RFXCOM transmitter.
I would like both systems to send the same KAKU signal. So each system can switch of or on a KAKU unit without double programming.
Or even better: I would like a KAKU remote, my HS2 and HS3 system to send the same signal.
HS3 for daily use and the HS2 and KAKU remote as backup.
Is this possible?
(I hope i explained it clearly)
Kind regards,
Jeroen
Controling KAKU (COCO) from different transmitters
- Jeroen Bartels
- b_weijenberg
Re: Controling KAKU (COCO) from different transmitters
No problem, use the ID and unit code of the remote in HS2 and HS3
