Decode Nexa-001 (HIDEKI TS04 sensor)
Novac
Post by Novac »
Hi
First I want to explain my setup.
In my main house I have Hum and Temp sensors from different vendors and I am using RFXtrx433E USB 433.92MHz to revieve sensor data.
I also have some Nexa switches and dimmers also working with RFXtrx433E.
In my second home, I am using an Acurite Bridge with several sensors Acurite 06044M and this has been working fine, but Acurite has discontinued the Bridge.
The replacement system I am working on is a RaspBerry Pi 3 with a RTL-SDR dongle.
During the replacement I plan an expansion and I have bought some Nexa-001 (HIDEKI TS04 sensor) Temp and Hum sensors which I want to use with the RTL_SDR dongle.
The reason for not using another RTXtrx433E is that the Acurite 06044M is not supported and cannot be decoded.
The RTL-SDR dongle decodes the Acurite 06044M fine.. BUT the RTL-SDR cannot fully decode the Nexa-001, the Sensor ID is not decoded as it is in RFXtrx433E
Now my question is, Can someone tell how the RFXtrx433E decodes the Nexa-001 (HIDEKI TS04 sensor) some code would be great or would it be possible to add support for the Acurite 06044M in RFXtrx433E ?
I am hoping for some help on this as I cannot afford replacing all my second home sensors
Regards
Jan
b_weijenberg
Re: Decode Nexa-001 (HIDEKI TS04 sensor)
Post by b_weijenberg »
contact support RFXCOM
