RFXPower
RFXPower
Hi All,
I have one of the new RFXPower meters.
- where can I found the documentation, unit is not sending any more..available documentation is for the old one.
- The Clamp-On is to big and it's not fitting in my electricity meter cupboard what can I do to let it fit.
Enver
Enver
- b_weijenberg
RFXPower
Enver,
The RFXMeter / RFXPwr documentation is on the download page http://www.rfxcom.com/documents/RFXMeter.pdf
If you have the possibility to extend the wire and bring a loop into an empty standard fuse box next to the current one you have plenty space for the CT? (and the RFXMeter)
Bert
Bert
RFXPower
Bert,
thank you for the link.
Te meter is working again..
I have put the meter on the main IN cable...I'm receiving data but have the feeling that the data is not correct...it's to high
can this work?
see the pictures
can this work?
see the pictures
- b_weijenberg
RFXPower
The CT must be clamped on 1 wire (not the whole cable)!!
It must be the hot - phase wire where you have to put the CT on.
Bend the Brown wire from the earth-leak switch to the main breaker a bit towards you and clamp the CT around that wire.
RFXPower
Bert,
I think have it now...
see the picture.
the brown cable is going true the CT
see the picture.
- b_weijenberg
RFXPower
perfect.
If you can turn the CT 90degrees it will probably fit in the box, isn't it?
RFXPower
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by b_weijenberg</i>
<br />perfect.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'm not sure will try that later.
I'm not getting any date since 40 min..did not change anyting...hope the time is set to 1 hour..
<br />perfect.
- b_weijenberg
RFXPower
Start RFreceiver,
Remove the power from the RFXMeter,
Connect the power adaptor again.
The RFXMeter will then transmit an init string with the interval time, firmware version and counter value.
RFXPower
In the RFreceiver iam getting data every 30 sec.
Data is not changed since yesterday 2202h
Init cmd to receiver => F02C
2C ACK
D01A2D4093012020E83BD3 THGR228N Inside Temp-Hygro CH 3 addr:93 temp:+20°C / 68°F hum:82 Wet bits=80 from SLAVE
B000F001540006 RFXMeter addr:00F0/240 RFXMeter: 340; RFXPower: 3,4 kWh; RFXPower-Module: 0,34 kWh bits=48 from SLAVE
D01A2D2032802320463036 THGR228N Inside Temp-Hygro CH 2 addr:32 temp:+23,8°C / 74,84°F hum:62 Comfort bits=80 from SLAVE
2C ACK
- b_weijenberg
RFXPower
Did you find the reason why the counter was not updated?
RFXPower
yes....the brown cable on the picture is not used...
I had to use the other one at the right side.
I put the CT in the lower part just above the meter.
