The RFXPulse can be used to measure electricity, gas, water usage or the pulse output of a device with a count output.
The RFXPulse is a module that can be inserted in the RFXMeter. http://www.rfxcom.com/sensors.htm#70095
This RFXPulse module allows you to measure:
• Pulses from a blinking LED’s (e.g. electricity meter),
• Reflection from a mirror or white field that is present on a digit in a gas meter (Dutch gas meter has a mirror),
• Pulses from a relay contact.
The LED pulse can be measured by using the photo sensor of the reflective-optical sensor. http://www.rfxcom.com/sensors.htm#70091 The LED in the reflective-optical sensor must be disabled by cutting the white/transparent wire in the jack plug.
The reflection of the mirror on the 6-digit in the Dutch gas meter can be measured using the reflective-optical sensor. It seems there are also UK gas meters with a white field in a digit that can be used by the reflective-optical sensor.
The pulse from a relay contact can be measured using the open-end cable. http://www.rfxcom.com/sensors.htm#70092 The relay contact must be a dry contact, in other words it must be a free contact without voltage present. There are water meters available with a pulse contact that can be connected to the RFXPulse using the open-end cable.
The RFXMeter can have 3 RFXPwr and/or RFXPulse modules inserted in any combination.
Bert
Measure electricity, gas and water with RFXPulse
- b_weijenberg
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
