Hi
Newbie, first question, hopes this is the rigth place...
Does anyone know these Plugin Modules: (See attached image).
They are 3-4 years old, bougth in ALDI. Marketed by Globaltronics GMBH, Hamburg.
According to the box documentation they operate on 433,92 Mhz.
So the biq question: Can they be controlled by RFXCOM?
Best Regards
hhg
Globaltronics/QUIGG Plugin modules
Moderator: b_weijenberg
- QUIGG Plugin Modules
- scan0002.jpg (214.46 KiB) Viewed 6887 times
Re: Globaltronics/QUIGG Plugin modules
Hello.
If you can open the device and look for the chipset
If this is PT2262/PT2272 chipset
Then it will work.
Most off this remote switch are working with the same chipset
Good luck
Ed
Then it will work.
Good luck
Ed
Did you made any progress with the quigg?
I'm not the guy that began that thread but I have the same issue. I've jut opened the wall plug and I can't identify any transmetter ; if I send you a picture, will you be able to help me ?
forward thanks
Guillaume
forward thanks
Guillaume
