In addition to my two ethernet RFXCOMs I got a RFXtrx433 today. What a nice size
Checked , did a firmware upgrade and connected it to my HS machine. Added it in the config and all seems fine but I can't find it back in the logs.
I have set them to debug1 and checked receiver and transmitter option.
The only ones I see in the log are Receiver #1 and #2, no sign of number 3 (the USB RFXtrx433)
How do I find out if it works in HS?
How to check a RFXtrx433
Re: How to check a RFXtrx433
disable the other two?
- b_weijenberg
Did you configure the RFXtrx433 in the Interfaces - transceiver section?
Did you test the RFXtxr433 using RFXmngr?
FOund the issue: I was filtering on Receiver but it bring "transceiver" into the logs. All seems fine.
Thanks for the fast feedback.
