Do you know how to get support for the Fine Offset 1081 weather station sensors via Rfxcom. My Rfxtrx433 appears to be picking up a couple of transmits. The first it picks up at TH9 Device #1, described as a Viking 02038, but the values bear no resemblance to anything the weather station control panel is showing.
The values it decodes as
icon th9 device #1 Kitchen 50.2 164 Wet 13:18:02
icon th9 device #2 6.8 Level 83 Wet 2014-03-09 19:34:01
Any ideas how to get these translated to real values?
Thanks
Ian
Fine Offset weatherstation support
- Starting Member
- b_weijenberg
Re: Fine Offset weatherstation support
Please use RFXmngr on a Windows system to see if it is correct received.
