Hi, i bought a RFXtrx433E a couple of days a go to use with my domoticz setup.
I had a WT440H outdoor temp/humid sensor laying around and hoped to add that device,
but the RFXtrx doesn't seem to notice it (tried with RFXmgr on Windows) .
The device itself works (there is an LCD on it), and you can select channels 1-15.
Any idea if it's something i should enable on the RFXtrx or does it only work on
a specific channel?
thanks in advance.
Ewald....
WT440H Temperature Humidity
Moderator: b_weijenberg
Re: WT440H Temperature Humidity
It is supported AFAIK using the Oregon protocol.
Do you not receive any signals at all?
Nico - Domotica in de Betuwe
Not 100% sure about that, but it was mentioned in below thread (but could not be relevant).
forums.indigodomo.com/viewtopic.php?f=2 ... amp;t=8633
Anyway, reading the manual should get you further.
- Starting Member
- Contact:
It might have something to do with the latest firmware 229 on my 433E,
i fell back to Type1_77 and now it's receiving and decoding the packets:
9/5/2014 7:38:46 PM= 0A520800010100DB3E0169
Packettype = TEMP_HUM
subtype = TH8 - WT260,WT260H,WT440H,WT450,WT450H
channel 1
Sequence nbr = 0
ID = 257
Temperature = 21.9 °C
Humidity = 62
Status = Comfortable
Signal level = 6
Battery = OK
Is there someplace to report this to? maybe others have the same issue.
And i'm not completely there yet, because today two TH12 Opus TX300 soil sensors
arrived, but they only show up when i enable "undec" and that doesn't give me
the info to work with of course
9/5/2014 7:51:16 PM= 1103090B66FCFFF9FFF3FFE7FFCFFF9FFF3F
Packettype = UNDECODED RF Message
UNDECODED OREGON3:66FCFFF9FFF3FFE7FFCFFF9FFF3F
9/5/2014 7:51:22 PM= 1303090C72FEFFFFFFFFFFFFFFFFFFFFFFF9FF03
UNDECODED OREGON3:72FEFFFFFFFFFFFFFFFFFFFFFFF9FF03
9/5/2014 7:51:27 PM= 1003090D5EFCFFFFFFF9FFF3FFE7FFCF3F
UNDECODED OREGON3:5EFCFFFFFFF9FFF3FFE7FFCF3F
these are my settings:
thanks in advance,
Ewald....
channel 1
Sequence nbr = 0
ID = 257
Humidity = 62
Signal level = 6
Battery = OK
Set Mode:0D 00 00 03 03 53 00 00 0C 27 00 00 00 00
9/5/2014 7:53:03 PM= 0D01000303534D000C2701020000
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 3
response on cmnd = Set Mode
Transceiver type = 433.92MHz
Firmware version = 77
Hardware version = 1.2
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech disabled
Oregon Scientific enabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
Ewald....
- Starting Member
- Contact:
played around with various firmware some more to see if i could
get to the point that both the WT440H and the TH12 Opus TX300
would be handled from my RFXtrx433E
Results so far:
firmware 229 => nothing
firmware Type1_77 and Type1_78 => show WT440H data
firmware Type2_178 => shows the TH12 data (see below).
So now i have to choose between the two
9/5/2014 8:32:31 PM= 0A520C05000200F0630379
subtype = TH12 - Imagintronix
channel 2
Sequence nbr = 5
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
9/5/2014 8:33:13 PM= 0A520C06000100F0050289
channel 1
Sequence nbr = 6
ID = 1
Temperature = 24 °C
Humidity = 5
Status = Dry
Signal level = 8
Battery = OK
Results so far:
channel 2
Sequence nbr = 5
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
channel 1
Sequence nbr = 6
ID = 1
Temperature = 24 °C
Humidity = 5
Status = Dry
Signal level = 8
Battery = OK
- Starting Member
- Contact:
Hmm, i am lost.
Back on firmware Type1_78
at first is only see the soil sensor,
after detachment en re-attachment of the RFXtrx
i only see the temp/humidity sensor.
It's giving me an iffy feeling about my RFXtrx443E
they should interfere with each other because they send at different times,
so what's going on...? (hears Marvin Gaye singing in the distance)
Reset receiver/transceiver:0D 00 00 00 00 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 01 02 00 00 00 00 00 00 00 00 00
0D01000102534E000C2701020000
Sequence nbr = 1
response on cmnd = Get Status
Firmware version = 78
Undec off
X10 enabled
ARC enabled
AC enabled
Meiantech disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
0A520C00000200F0630389
channel 2
Sequence nbr = 0
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 8
Battery = OK
0A520C01000200F0630379
channel 2
Sequence nbr = 1
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
Set Mode:0D 00 00 02 03 53 00 00 0C 27 00 00 00 00
9/5/2014 9:11:32 PM= 0D01000203534E000C2701020000
Sequence nbr = 2
Undec off
X10 enabled
ARC enabled
AC enabled
Meiantech disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
9/5/2014 9:21:17 PM= 0A520C02000200F0630379
channel 2
Sequence nbr = 2
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
9/5/2014 9:22:46 PM= 0A520C03000200F0630379
channel 2
Sequence nbr = 3
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
9/5/2014 9:24:14 PM= 0A520C04000200F0630379
channel 2
Sequence nbr = 4
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
Reset receiver/transceiver:0D 00 00 03 00 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 04 02 00 00 00 00 00 00 00 00 00
9/5/2014 9:37:16 PM= 0D01000402534E000C2701020000
Sequence nbr = 4
Undec off
X10 enabled
ARC enabled
AC enabled
Meiantech disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
Get Status:0D 00 00 05 02 00 00 00 00 00 00 00 00 00
9/5/2014 9:37:25 PM= 0D01000502534E000C2701020000
Sequence nbr = 5
Undec off
X10 enabled
ARC enabled
AC enabled
Meiantech disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
9/5/2014 9:39:01 PM= 0A520C00000200F0630379
channel 2
Sequence nbr = 0
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
9/5/2014 9:40:30 PM= 0A520C01000200F0630379
channel 2
Sequence nbr = 1
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
9/5/2014 9:43:27 PM= 0A520C02000200F0630379
channel 2
Sequence nbr = 2
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 7
Battery = OK
Reset receiver/transceiver:0D 00 00 06 00 00 00 00 00 00 00 00 00 00
Get Status:0D 00 00 07 02 00 00 00 00 00 00 00 00 00
9/5/2014 9:47:40 PM= 0D01000702534E000C2701020000
Sequence nbr = 7
Undec off
X10 enabled
ARC enabled
AC enabled
Meiantech disabled
ATI disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20 disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
RSL disabled
Byron SX disabled
RFU disabled
9/5/2014 9:49:46 PM= 0A520800010100EE3D0159
channel 1
Sequence nbr = 0
ID = 257
Temperature = 23.8 °C
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:51:46 PM= 0A520801010100EE3D0159
channel 1
Sequence nbr = 1
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:52:46 PM= 0A520802010100EE3D0159
channel 1
Sequence nbr = 2
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:53:46 PM= 0A520803010100EE3D0159
channel 1
Sequence nbr = 3
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:54:46 PM= 0A520804010100EE3D0159
channel 1
Sequence nbr = 4
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:55:46 PM= 0A520805010100EE3D0159
channel 1
Sequence nbr = 5
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:57:46 PM= 0A520806010100EE3D0159
channel 1
Sequence nbr = 6
ID = 257
Humidity = 61
Signal level = 5
Battery = OK
9/5/2014 9:58:46 PM= 0A520807010100EE3E0159
channel 1
Sequence nbr = 7
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 9:59:46 PM= 0A520808010100EE3E0159
channel 1
Sequence nbr = 8
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:00:46 PM= 0A520809010100EE3E0159
channel 1
Sequence nbr = 9
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:01:46 PM= 0A52080A010100EE3E0159
channel 1
Sequence nbr = 10
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:02:46 PM= 0A52080B010100EE3E0159
channel 1
Sequence nbr = 11
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:03:46 PM= 0A52080C010100EE3E0159
channel 1
Sequence nbr = 12
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:04:46 PM= 0A52080D010100EE3E0159
channel 1
Sequence nbr = 13
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:05:46 PM= 0A52080E010100EE3E0159
channel 1
Sequence nbr = 14
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:06:46 PM= 0A52080F010100EE3E0159
channel 1
Sequence nbr = 15
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:07:46 PM= 0A520810010100EE3E0159
channel 1
Sequence nbr = 16
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:08:46 PM= 0A520811010100EE3E0159
channel 1
Sequence nbr = 17
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:09:46 PM= 0A520812010100EE3E0159
channel 1
Sequence nbr = 18
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:10:46 PM= 0A520813010100EE3E0159
channel 1
Sequence nbr = 19
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:11:46 PM= 0A520814010100EB3E0159
channel 1
Sequence nbr = 20
ID = 257
Temperature = 23.5 °C
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:13:46 PM= 0A520815010100EE3E0159
channel 1
Sequence nbr = 21
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
9/5/2014 10:14:46 PM= 0A520816010100EE3E0159
channel 1
Sequence nbr = 22
ID = 257
Humidity = 62
Signal level = 5
Battery = OK
- b_weijenberg
- Forum Moderator
UPM/ESIC is only supported in Type1 firmware. See chapter 2.2.2 in the RFXtrx User Guide
