Dx rgb controllers
Momomx3v6
Dx rgb controllers
Post by Momomx3v6 »
I have both dx.com rgb controllers.
The
http://dx.com/p/rf-remote-touch-rgb-controller-130913
And the
dx.com/p/wireless-touch-panel-remote-co ... ight-67412
How can I find the right code to use the controller?
And, the first one must be learnable, do somebody know how this works? There is no learn button on the controller!
b_weijenberg
Re: Dx rgb controllers
Post by b_weijenberg »
A new TRC02 is sold. It has the same type but a different protocol.
Firmware version 230 for the RFXtrx433E supports both now.
See also the RFXtrx User Guide how to find the ID's.
Momomx3v6
Post by Momomx3v6 »
I have the Rfxtrx433 not the rfxtrx433e
Is it possible to find the code with the rfxtrx433?
I try everything with the new firmware!
The trxmngr find nothing at al.
Try all the protocols.
On the other one it get some codes on the lightning4 protocol.
091300003a9d42015e60
Packet type=lightning 4
Subtype=pt2262
Sequence nbr=0
S1- s24= 0011 1010 1101 0100 0010
Pulse = 350 user
Signal level =6
The other strange ting, with ad/lightwaveRF on in the trxmngr it don't find a signal
If I turn the ad/lightwaveRF and the arc on, it find this
0a1402710753a802000060
Packet type=lightning 5
Sub type= bbsb new
Id= 0753a8
Unit=2
Command=off
Signal level=6
And the most buttons show an another code.
It drives me a little crazy :-(
b_weijenberg
Please use the latest version of RFXmngr!
091300003A9D42015E60
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 0
Code = 3A9D42
S1- S24 = 0011 1010 1001 1101 0100 0010
Pulse = 350 usec
Signal level = 6
Note: TRC02_2 is only supported by the RFXtrx433E
esschenk
Post by esschenk »
Hello Bert,
It’s a bit confusing about the controller
http://www.dx.com/p/rf-remote-touch-rgb ... HBoGvmG_Qg
Witch controller is using witch RFXtrx
You have 2 types of remote’s 1 with 2 batt
And 1 with 3 batt.
I have the one witch 3 Batteries and the RFXtrx without the E
Thanks Ed.
b_weijenberg
Ed,
I guess the controller in your link is OK but.....
I have had now 3 times that the same order code had a different protocol and they also delivered a product with a different type.
I ordered for example a WT0122 water temp sensor (SKU: 189750). The picture clearly indicates WT0122 but they delivered a KG122 which is using a totally different protocol.
I stop implementing dx.com products for this reason.
Bert
Momomx3v6
Post by Momomx3v6 »
I bought an another rgb controller,
Got one with 3 batteries, and it displays the code a731 and there is no A7 code in the list in the rfxmngr :-(
Does that mean i can not use this rgb controller with the rfxcom?
The other one works just fine!
