An updated firmware version is available on the RFXCOM download page:
. RFY program command changed
. Number of RFY remotes increased from 30 to 40
. Byron MP001 transmit added
. WT0122 pool thermometer added (maybe also Kjell 48019 Rubicson)
. Eurodomest (NL - Action) added
. TRC02 receive improved
. support for the new TRC02 (with 3 batteries in the remote) added
. Viking temperature measurement extended
Check the RFXtrx User Guide which firmware supports the new devices
Updated RFXtrx433 firmware
- b_weijenberg
Re: Updated RFXtrx433 firmware
Just wondering, which products are supported by this?Eurodomest (NL - Action) added
Eurodomest seems to be the company behind the Calex range of lighting products but the site is a bit too overwhelming to check if one of the lamps support 433 MHz control.
- b_weijenberg
It is sold by Action in The Netherlands. Set of 3 modules including remote at €10
http://catalogus.electrocirkel.com/nl/c ... uct/972080
Control these modules with Lighting1 - ARC
