Is this protocol supported by the 433mhz e usb transceiver?
http://wiki.pilight.org/doku.php/threechan
If not, is it possible to support it in the future?
I'm willing to send raw dumps etc.
three Chan protocol
- b_weijenberg
Re: three Chan protocol
sent you a PM
Can't reply to the pm.
But the sensor is the one that came with this station.
http://www.alecto.nl/weerstation-1700
In pilight it works with the threechan protocol for temp, humidity and battery level.
The pilight alecto protocol only works for temp.
- b_weijenberg
As indicated in the PM contact support rfxcom.com
- b_weijenberg
The Alecto WS1700 and compatible protocol is added in the RFXtrx433E firmware version 232.
Enable the Rubicson protocol to receive this sensor.
Drawback for this sensor type is that it does not have a checksum byte and you will receive sometimes wrong values as a result of a bad RF packet!
Use this type of sensor only for temp/hum display and not for control of heating or ventilation.
