Real-time online websites
Put a link of your Home Automation, Domotica website here.
123unlock
Re: Real-time online websites
Post by 123unlock »
take a look at our little project at http://www.xtrusion.nl
at the moment we have several devices in and around the house connected to our home-made domotica system
protocols in use:
- Z-Wave (Powermeters/switches)
- RFXTRX433 (oregon, klikaanklikuit, elro)
- Plugwise (Powermeters/switches)
- 1-Wire Bus
data is stored in a database and displayed "semi-realtime" at the website
Xtrusion Digital Home Automation Project
OWK
Post by OWK »
Fine result!
You report presence using WiFi.
How do you detect the WiFi signal from the mobile devices?
Missed some technical details of your domotica software on the site...
Regards
OWK
Domotiga
Cubietruck, Ubuntu server 1.0.2
RFXcom LAN, home brew ground plane antenna
KaKu
123unlock
Post by 123unlock »
Wifi Presence is done by making an fixed IP address for the phone
in the main router i configured per phone/computer an fixed IP adress in the dhcp scope (based on the mac address)
our domotica client is doing a single ping to each device every 2 secs. to prevent false positives i added an beacon counter per device
if there where 25 missed pings after each other the system will set the device to "out of home" after an other 25 good ping replies it
will turn it back to "available"
i must say it works pretty stable, as one minute after i leave for work it will set my device offline
one problem was each device should have wifi enabled as soon as they come near the house (this is done by an android app to switch on wifi based on cell-tower id location) so if 'm in reach of tower x and y signal it will auto turn on my wifi and connect to home
OWK
Post by OWK »
Creative solution you have.
So if the phones' WiFi is always on, it does not connect to your private network if in range?
Thanks for sharing!
Reagrds
OWK
Domotiga
KaKu
kriz83
Post by kriz83 »
RoelFloor wrote:I've spent the last few weeks reading about Smart Meters and stuff...
There are a lot of solutions to choose from. Got the components and finally got something online.
See it at: http://home.roelfloor.nl and read about it at (in dutch, though): http://www.roelfloor.nl
What components did you use ?
neomess
Post by neomess »
Can you add my site to the list: www.neomess.nl
And can you unblock my "Who has a realtime website" topic? I know it wasn't working for a little while due to a relocation of my server, but i didnt have time to straighten this out before u removed the toipic.
Visit my realtime website: http://www.neomess.nl
Return to “Who has a realtime website”
