Kan niet pingen vanuit Linux??
Postby Merdeka » Tue Jun 02, 2009 2:02 pm
Hi everyone,
I started writing a KNX/EIB module for DomotiGa. I have bought a KNX IP Interface 730 at http://www.weinzierl.de/main/main_ip_interface.html. The interface worked fine for one evening on my Ubuntu Laptop in combination with EIBD. But it has stopped working under Linux now.
Using Windows XP everything is fine. I can ping the 730IP and ETS works like it should.
Using my Linux systems (Ubuntu Laptop, Dreambox 7025, NSLU2 running openwrt) I can't even ping. The rest of the network is OK, only the 730IP is unpingable.
I have no idea what's wrong.
Annyone??
Timo
edit: Translated to English..
Merdeka
Postby Snelvuur » Tue Jun 02, 2009 2:07 pm
English...
Snelvuur
Postby Merdeka » Wed Jun 03, 2009 2:19 pm
Solved...
Pinged from linux with option -s 32
So I quess Windows uses a different byte size when pinging.
Merdeka
Postby Snelvuur » Wed Jun 03, 2009 2:22 pm
Could be you have some standard firewall from xp, or mcaffee which denies certain "standard" types of icmp ping.
Snelvuur
Return to Linux Forum
cron
