Ip camera on linux
Ip camera on linux
Postby Kroonen » Thu Jul 16, 2009 7:26 am
i'm looking for an ip camera which works with linux with the following requirements.
grab images/movies on motion detection, from a linux machine with a console based tool
has a builtin webserver
day/night view
any ideas?
Kroonen
Ip camera on linux
Postby ddgiel » Thu Jul 16, 2009 10:41 am
See overview off http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2482&SearchTerms=camera%2Cmobotix"
I have a mobotix
- ip camera
- owner webserver
- motion detection
- day/night view
- Serial interface
- API Interface via http
- FTP
What do you mean by a console based tool?
ddgiel
Ip camera on linux
Postby ddgiel » Thu Jul 16, 2009 10:48 am
If the night view is important, you can add an IR lamp near the camera.
This is usually a big improvement to the images at night.
ddgiel
Ip camera on linux
Postby Snelvuur » Thu Jul 16, 2009 8:52 pm
Just get a "ip camera" then use a program called "motion" for linux, which can detect changes, and also record movie/timestamp etc, also support lots of camera's on usb etc etc, i would look at motion (i used that for a long time)
Snelvuur
Ip camera on linux
Postby Kroonen » Thu Jul 16, 2009 9:43 pm
So an axis 1011-w or 1031-w should work???
Kroonen
Ip camera on linux
Postby Snelvuur » Fri Jul 17, 2009 4:57 pm
That should work yes, with motion you can just point it to a weburl (to get the picture) and it checks the difference between the 2, thats how it detects motion. Since its ip based, you allready have a http interface. Only need to check if its day/night, has ftp and such.. but i dont see a reason to have ftp on a camera though (since you can use motion on a linux box and do/ftp whatever you want) but double check on the website to see if its all supported what you want.
Snelvuur
Ip camera on linux
Postby cscm » Fri Jul 17, 2009 5:07 pm
You shoud check http://www.zoneminder.com.
My 0.002$
cscm
Return to Linux Forum
