Run program on USB disconnect
Forum regarding Windows Software and Home Automation Domotica.
Postby Lennart » Thu Apr 23, 2009 10:45 am
I was wondering: does anybody know of a (Vista compatible) utility that allows you to specify a program to run on DISconnection of a USB device? My touchscreen drivers are a bit flaky and this sometimes leads to a disconnect. I would like to be able to detect this event and run a program whenever it happens.
Thanks!
Lennart
Lennart
Postby Edwin2008 » Sat May 16, 2009 10:01 am
you could look at
http://quick.mixnmojo.com/usb-disk-ejector
and if you want the usb device to keep it's drive letter
http://www.uwe-sieber.de/usbdlm_e.html
and if you would like to autmate some thing then here is a suggestion
http://forums.cnet.com/5208-6122_102-0. ... dID=273629
oeps, misundrstand the post. well anyway perhaps it is for another moment :)
Edwin2008
Postby Lennart » Sat May 16, 2009 11:23 am
Thanks Edwin; that's indeed not the solution to my problem :-). I've solved it for the moment by checking every two minutes whether the touchscreen driver is still running. It works, though it's not a very satisfactory solution.
Lennart
Lennart
Postby dutchnomad » Sat May 16, 2009 11:47 am
Dit lijkt me wel een oplossing:
http://www.codeproject.com/KB/system/DriveDetector.aspx
Dutchnomad
dutchnomad
Postby Lempens » Sat May 16, 2009 1:12 pm
Or you can use the Microsoft program DevCon. Put the program in a scheduler, and let it reconnect the USB device every 30 minutes.
http://support.microsoft.com/kb/311272
"c:\devcon.exe disable @usb\ *vid_10c4*"
Where you have to change vid_10c4 to your usb device.
to enable the device use "c:\devcon.exe enable @usb\ *vid_10c4*"
I use this when my PMIX35 from Xanura hangs. A couple of times a week the PMIX35 hangs. When my program detects it, it run above command's.
Lempens
Return to Windows Forum
