"flikkeren" 230v LED lamp without dimmer
Moderator: Mversluis
Postby DJF3 » Fri Jun 26, 2015 1:46 pm
I recently purchased a LED lamp (G9, 3W, 230v) where you can notice some flickering (not very clear but you do see some "onrust" in the light)
It's connected to a normal switch, no dimmers.
G9 LED 3W
An example of how this looks: Note that the phone camera will emphasize the flickering WAY more than it is in real life!
Left: G9 LED lamp, right: Halogen G9 lamp
Q: Any idea what causes this?
Q: Can it be solved?
Wondering if this is a quality issue or something that just cannot be fixed?
Cheers!
DJ
DJF3
Re: "flikkeren" 230v LED lamp without dimmer
Postby raymonvdm » Fri Jun 26, 2015 2:58 pm
It can be an issue with the powerfeed for example corrosion on the contacts or an issue with Fase / Zero. Make sure the brown (L1) is connected to the plus of the bulb and the blue (null) to the minus of the bulb. Did you als try reversing the bulb?
raymonvdm
Return to LEDS, DMX & Lights Forum
