Z-Wave controlled LED Strips?
Moderator: Mversluis
Postby hettelade » Mon Jan 10, 2011 11:20 pm
Hello people,
I got 5 meters of RGB LED strip, that I want to controle via some Z-Wave device.
Today I controle it with this RF unit - http://www.alibaba.com/product-gs/36286 ... er_RF.html
Anyone know if such a device exists?
Best regards
Mike
hettelade
Re: Z-Wave controlled LED Strips?
Postby Esteban » Tue Jan 11, 2011 12:19 am
Hi welcome to the forum,
There's no 'kant-en-klaar' Z-wave RGB controller available at this moment that allows you to control LED's like the box you have right now, as far as I'm aware.
Esteban
Postby hettelade » Tue Jan 11, 2011 7:24 am
Ahh, thats a shame :-/ Thanks for the answer tho.
So, for this to work, I need to tinker with something myself?
Next question, is it possible to get some sort of a Z-Wave kit, with 3 outputs, eather digital or analog, to use with a selfbuild controler for the LED strip?
I know there is a Z-Wave dev kit available, but Im not willing to spend that kind of money on a dev kit, and sign up as a developer :-)
//Mike
hettelade
Postby Esteban » Tue Jan 11, 2011 3:37 pm
Making something yourself is your best bet at this moment in time imho.
Since you already have a controller, I suggest opening the remote. Have a look inside to see if there are contact-points on which you can solder some wires. You could then hook those wire in an external IPpower-like device and then operate it from, for example, Homeseer.
Esteban
Postby Mversluis » Tue Jan 11, 2011 3:57 pm
From our company there is a large wish to control leds and RGB leds true the zwave solution.
Depending of the domotica you will use there are some solutions.
In the next few weeks / months we will work on a proto type to connect the RGB , Power leds and others to Vera and/ or Qees master.
So work in progress.
Marco
Mversluis
Postby hettelade » Sun Jan 16, 2011 10:12 am
Ohh, thats exelent News!! I will look forward to see what kind of solutions you come up with :-)
//Mike
hettelade
Postby maartenvt » Sun May 01, 2011 9:58 pm
@ mversluis
What is the status of the z-wave rgb solution?
maartenvt
Postby Harry » Mon May 16, 2011 5:41 pm
i all so like to now what the status is??
Postby Futuretech » Thu Dec 08, 2011 7:46 pm
I think Fibaro has the solution?
Futuretech
Postby Digit » Fri Dec 09, 2011 12:47 am
Arduino is the solution! Almost PnP (you have to stack some shields yourself), HTTP protocol support ("Web based"), what more do you need?
Wifi maybe? Doable too.
http://blog.hekkers.net/tag/dmx/
Return to LEDS, DMX & Lights Forum
cron
