Dimmable LED driver
Moderator: Mversluis
Dimmable LED driver
Postby phoenixb » Sat Jan 14, 2012 8:19 pm
I'm searching on the Internet for a Dimmable LED driver with the next specs:
- Input (dimmeble) 230Vac 50Hz
- Output 12Vdc (for about 6 Led's)
Is there someone that knows where i can find this kind of LED drivers.
I like to know it.
__________________
phoenixb
Re: Dimmable LED driver
Postby KidE » Mon Jan 23, 2012 9:50 pm
I have one here at home that i'm not using at the moment.
It's a 12V 24Watt dimmable by 0-10V or by trailing/leading edge external (traditional) dimmer.
if your interested mail me at ernst[puntje]cozijnsen[apenstaartje]gmail[puntje]com
KidE
Postby Edwin2008 » Tue Jan 24, 2012 9:25 am
i think megaman has a dimmable (0-10v) driver (http://www.megaman.nl/spaarlampen/cfl10 ... oductinfoA)
** edwin **
Edwin2008
Postby Mversluis » Mon Jan 30, 2012 10:22 pm
There are a several options to use.
But first of all please count the light together and inform the total wattage usage. That will be the most important.
Marco
Mversluis
Postby Lan Harjochee » Tue Apr 24, 2012 10:00 am
I have read that this LED bulbs can make an interference so you can switch them on but in some cases you can not switch them off anymore...
Marmitek recomments using the FM10 or FD10 modules to filter this interference.
Lan Harjochee
Return to LEDS, DMX & Lights Forum
