PEP v2 has been released
Check http://www.pronto.philips.com/index.cfm?id=1635 for more info.
There are some major changes, issues etc. so visiting
http://www.remotecentral.com/cgi-bin/mb ... o/list.cgi before upgrading is a good thing to do.
Snelvuur
Post by Snelvuur »
I've placed it in the files sections.
http://files.binkey.nl/Pronto/PEP/Pront ... _Setup.zip
Great!
If somebody does the upgrade please tell about it.
Snelvuur
Post by Snelvuur »
i got vista 64 bits, first need to force it to 32bits it seems.. wont work out of the box for those that have 64 bits.
Bastiaan
Post by Bastiaan »
quick look:
User interface is completely different, also the way it handles learned codes.
It looks good but the 'expanded' device database still doesn't have any of my missing devices :-(
Better simulator with resizing.
It runs stable on Vista32.
From the help file:
With this 2.0 release, we have radically redesigned ProntoEdit Professional. As it is "designed by installers, made by Philips", we have catered to the needs of the custom install professional:
ProntoEdit Professional 2.0 is now entirely activity-based.
UI programming and component set-up have been split, improving the structure and re-use of projects. This provides an elegant alternative for the hidden code pages and links methodology of the 1.0 version.
As a result of this new structure, the efficiency of the drag & drop functionality has increased immensely. You can now drag & drop all the elements you need where you need them.
Bastiaan
I'm back to version 1.x
getting lot of error's when importing my projects.
Enver,
Could you tell more about what kind of errors, are they fixable? or did the import just stop?
Import is finishing with lot of errors
at the end some functions are not working
this kind of errors few pages long.
Custom IR Code in button "TV" on page "Home" of activity "Home" could not be imported
Learned IR Code
0000 006d 0000 000b 0021 0022 0043 0022 0021 0022 0021 0022 0021 0045 0021 0022
0043 0022 0021 0022 0021 0045 0043 0022 0021 0dd8
I think I wait with updating :-)
The new interface looks okay...but I don't see what it will bring extra...
I hope they will upgrade the firmware with WPA and WPA2 support
You're right Enver, Philips has to get rid of WEP, that's much more important then a PEP v2 that seems to have problems with learned IR codes...[V]
Return to “Philips Pronto (TSU9600), IRtrans and other remotes”
