Pronto Edit v 2.1.18
Bastiaan
Post by Bastiaan »
The new version Pronto Edit supports 64bit. Since I am runing mainly 64bit that was nice to see. If I download the file from the Philips website I get a corrupt version.
Did anybody managed to get the program decently unzipped?
If so, please update the file section with it too.
Snelvuur
Post by Snelvuur »
Try the files section under "Pronto/PEP"
Bastiaan
Post by Bastiaan »
Hi Erik,
Think you did not read the message good enough or I was not clear:
The PEP file here on the server has a date stamp of November, the Philips one came out in December. It might be a good idee to add the version in the filename, (as Philips does).
Bastiaan
Snelvuur
Post by Snelvuur »
http://files.binkey.nl/Pronto/PEP/Pront ... 2_1_18.zip
after you posted your message, i did just that.. i think you still need to do F5 (refresh).. :-)
Bastiaan
Post by Bastiaan »
Can't keep up with your speed :-) (What's in the name)
Did you unzip it as test?
Txs a lot!
Bastiaan
Post by Bastiaan »
This one unzipps without a hitch.
May be good idee to add the latest 6.xxx firmware update too?
Thanks Erik.
Do you have the latest firmware also?
Snelvuur
Post by Snelvuur »
Well i normally just download these things from remotecentral or philips site and then i just upload them..
but i added 9400 & 9600 firmware to it.
Bastiaan
Post by Bastiaan »
V2.1.18 does not run on Windows 7 x64, not even in compatibility mode :-(
It starts but I run in all sorts of problems, no loading of the DB's, gallery import hangs or stops etc.
Did anybody test it on Vistax64?
Return to “Philips Pronto (TSU9600), IRtrans and other remotes”
