Can TSU9400 and X10 be combined?
Postby vasquez » Wed May 20, 2009 12:12 am
Can the Philips TSU9400 be used for controlling my x10 lighting through (433) RF?
I own a 'old' TSU700 but it can not do RF over 433 since it was an US model. Through a Marmitek IR converter i can control my x10 devices but only when i am pointing straight at the converter which really sucks and does not seem to be very reliable.
I am looking for a RF solution but as i have read the new generation of pronto's (TSU9600, 9400, etc) does RF over 2,4ghz.
Is there a way to use the new generation of Pronto's with all my X10 devices?
vasquez
Postby Bjochems » Wed May 20, 2009 9:21 am
No, because the TSU9600 does not have RF.
But you can use the Wireless Extender RFX9400. The Pronto Remote and the Extender will then communicate by Wifi. Then you can connect a IR cable from the extender to your Marmitek IR converter to control your lights.
Bjochems
Postby vasquez » Wed May 20, 2009 9:30 am
ok, thnx for your reply!
just to be sure,do you mean that i finally can place my (ugly) ir7243 in a closed cabinet and by using an IR cable with an 'eye' i can transmit the IR signals from the extender to my ir7243?
vasquez
Postby Bjochems » Wed May 20, 2009 10:29 am
Yes that's right.
You can read it all in the [url="http://www.pronto.philips.com/library/documents/RFX9400_SG_DE_NL_RU.pdf"]Manual][/url].
Bjochems
Return to Philips Pronto (TSU9600), IRtrans and other remotes
