IR TSOP
Forum about hardware/software for the Philips Pronto TSU9600 and other remotes.
IR TSOP
Postby Merdeka » Mon Aug 17, 2009 12:29 pm
Hey,
I've spend the weekend fooling around with a simple homebrew IR reciever. Realy simple RS232 on a breadboard (http://www.lirc.org/receivers.html). I've used a TSOP7000 because I have a Bang & Olufsen BEO4 remote lying around.
After configuring LIRC for the BEO4, I wrote a LIRC-TCP client for DomotiGa and some code so DomotiGa can send OSD-info to XBMC.
Everything works nice. I can use the BEO4 to control XBMC on my Ubuntu server and when I switch the lighting on or off I get an OSD message in XBMC..... :)
Nice thing about the BEO4 is that it have a dedicated light button.
So far so good..
The BEO4 uses 455KHZ and easily reaches 10 meters, so thats great. However, Being IR it won't go through a wall.
Can I just put 3 TSOP7000 in parallel?
Timo
Merdeka
IR TSOP
Postby Snelvuur » Mon Aug 17, 2009 1:01 pm
Can always get a IR extender.
Snelvuur
IR TSOP
Postby Merdeka » Mon Aug 17, 2009 1:38 pm
Most IR extenders work only well from 36-38khz. Not the 455khz B&O uses. IRTrans has special B&O versions of their hardware for this same reason.
Merdeka
IR TSOP
Postby Snelvuur » Mon Aug 17, 2009 1:49 pm
didn't irtrans also have a B&O version, although that is perhaps too much for what you want.
Snelvuur
Return to Philips Pronto (TSU9600), IRtrans and other remotes
