IRTrans - how to configure automatic passthrough of signals?
Postby DJF3 » Thu Aug 20, 2009 1:42 pm
Right now I have a marmitek device that captures my IR signals and extends them to the devices (cable decoder, media player) that are inside a closet. (wired extension!)
Can I use the IRTrans receiver LED to capture the signals and automatically send them to the decoders & media players?
Important: this should work without HomeSeer.
HomeSeer will ofcourse also receive the signals but won't do anything for most of these signals.
thanks
DJ
DJF3
Postby TANE » Thu Aug 20, 2009 3:18 pm
DJ in the config menu you can select the self repeat option.
Signals will be send to the internal and external outputs.
http://twitter.com/Chak64%20My%20Domotica%20Log%20www.tane.nl/domotica/hardware.html<i> My Domotica Hardware Software</i></font id="size1">
Postby DJF3 » Fri Aug 21, 2009 7:49 am
CHECK! Going to test this right away
DJ
DJF3
Postby DJF3 » Sun Aug 23, 2009 9:55 am
This works. The only problem is that it adds a 0.3-0.5 second delay. This means that if you're scrolling through a list (EPG) it's feels like it responds slowly.
Is this an inevitable delay added by the IRtrans electronics?
Thanks
DJ
PS. When should I see IR signals appearing in my HomeSeer logfile? The I/R Match event trigger is not working.. HS <i>can</i> send IR signals.
DJF3
Return to Philips Pronto (TSU9600), IRtrans and other remotes
cron
