Homeseer status on Pronto
Postby tenholde » Fri Aug 01, 2008 2:58 pm
Anyone know if prontoscript is available on the Pronto Pro NG TSU7000?
tenholde
tenholde
Postby Snelvuur » Fri Aug 01, 2008 3:03 pm
i think its only with the 9600/9400 models. My biggest issue is that i have to load the data to the pronto always to test it again, which is a real setback. (if such a tool was there you could test it too without the need of a real pronto)
Snelvuur
Postby stefxx » Sat Feb 07, 2009 10:01 pm
Hi Chak,
Do you have a working example (perhaps a .xcf) on how to retrieve the device status from homeseer? I installed the tenHsServer scripts but I need some help in interpreting the return values in ProntoScript...
Thanks!
stefxx
Postby TANE » Sun Feb 08, 2009 12:30 pm
@Sddroog,
I have a good working .xcf
I can send you this...just send me a pm with your e-mail
Postby stefxx » Mon Feb 09, 2009 2:11 pm
Thanks, looks very promising. I will play with it in the next few days.
stefxx
Postby stefxx » Sun Feb 15, 2009 8:15 pm
It works great, thanks a lot! I can recommend it!
stefxx
Postby TANE » Sun Feb 15, 2009 9:00 pm
Can you show some examples of what you have build?
Postby stefxx » Wed Feb 18, 2009 7:45 am
I started with modifying your weather page with my own devices and adjusted it for a 9400 screen. That was easy. Then I modified my regular home automation pages (mostly lights and shutters) to indicate whether the device was switched on, off or dim %. Now I don't have to turn the bathroom lights off if unsure about the status, I can simply see if it is switched off already.
Your script assumes that all devices using the same prefix/house code. That was fine for the first few pages I created but after a while I changed it so it will more easily support different house codes on one page.
I also moved away from Prontonic. I still think it is a great implementation but as long as it doesn't support two way communication, it won't do. There is too little going on with Prontonic to think the author will ever implement two way support. So I created another script (based on yours) to allow controlling devices with on, off, dim etc.
I don't know how to make screenshots from a running pronto, and the simulator doesn't support network connections so 'show some examples' it not that easy. But if people are interested I can make a simplified .xcf and sent it. For now, just image that the weather values are there and that the text on the devices (ie "voor") changes to reflex the status (ie "Voor: aan")
Image Image
stefxx
Postby TANE » Wed Feb 18, 2009 9:44 am
Nice work.
Can you please send me a copy of your pronto config?
Postby stefxx » Wed Feb 18, 2009 12:51 pm
Zit in je mailbox!
stefxx
Postby Snelvuur » Wed Feb 18, 2009 1:51 pm
maybe nice to put it online for other to see..
and dont forget to keep it in english :) (i make the same mistake now and then too)
Snelvuur
Postby stefxx » Wed Feb 18, 2009 2:10 pm
Whoops, English, you're right.
Can I attach it to this thread or upload it somewhere here? It is about 400kb...
stefxx
Postby TANE » Wed Feb 18, 2009 4:23 pm
upload here is max 200 kb
You can send the file to Snelvuur or to me for upload to another place.
Postby Snelvuur » Wed Feb 18, 2009 4:44 pm
On the topic of the site you can see a "files" link, Chak or me or pieter can put it there (has 100mb limit per file)
Snelvuur
Postby TANE » Wed Feb 18, 2009 9:02 pm
Pronto interface/scripting what is developed by sddroog
This config file is for the Pronto TSU 9400 but can easly be converted to TSU 9600
Basic functions for Homeseer control with two way communication.
DeviceOn
Deviceoff
DeviceDim
DeviceBright
DeviceEvent
http://files.binkey.nl/Pronto/Modules/H ... motica.xcf
PreviousNext
Return to Philips Pronto (TSU9600), IRtrans and other remotes
