Page 6 of 7
Homeseer status on Pronto
Posted: Fri Aug 01, 2008 3:58 pm
by tenholde
Anyone know if prontoscript is available on the Pronto Pro NG TSU7000?
tenholde
Posted: Fri Aug 01, 2008 4:03 pm
by Snelvuur
i think its only with the 9600/9400 models. My biggest issue is that i have to load the data to the pronto always to test it again, which is a real setback. (if such a tool was there you could test it too without the need of a real pronto)
Posted: Sat Feb 07, 2009 11:01 pm
by stefxx
Hi Chak,
Do you have a working example (perhaps a .xcf) on how to retrieve the device status from homeseer? I installed the tenHsServer scripts but I need some help in interpreting the return values in ProntoScript...
Thanks!
Posted: Sun Feb 08, 2009 1:30 pm
by TANE
@Sddroog,
I have a good working .xcf
I can send you this...just send me a pm with your e-mail
Posted: Mon Feb 09, 2009 3:11 pm
by stefxx
Thanks, looks very promising. I will play with it in the next few days.
Posted: Sun Feb 15, 2009 9:15 pm
by stefxx
It works great, thanks a lot! I can recommend it!
Posted: Sun Feb 15, 2009 10:00 pm
by TANE
Can you show some examples of what you have build?
Posted: Wed Feb 18, 2009 8:45 am
by stefxx
I started with modifying your weather page with my own devices and adjusted it for a 9400 screen. That was easy. Then I modified my regular home automation pages (mostly lights and shutters) to indicate whether the device was switched on, off or dim %. Now I don't have to turn the bathroom lights off if unsure about the status, I can simply see if it is switched off already.
Your script assumes that all devices using the same prefix/house code. That was fine for the first few pages I created but after a while I changed it so it will more easily support different house codes on one page.
I also moved away from Prontonic. I still think it is a great implementation but as long as it doesn't support two way communication, it won't do. There is too little going on with Prontonic to think the author will ever implement two way support. So I created another script (based on yours) to allow controlling devices with on, off, dim etc.
I don't know how to make screenshots from a running pronto, and the simulator doesn't support network connections so 'show some examples' it not that easy. But if people are interested I can make a simplified .xcf and sent it. For now, just image that the weather values are there and that the text on the devices (ie "voor") changes to reflex the status (ie "Voor: aan")
Posted: Wed Feb 18, 2009 10:44 am
by TANE
Nice work.
Can you please send me a copy of your pronto config?
Posted: Wed Feb 18, 2009 1:51 pm
by stefxx
Zit in je mailbox!
Posted: Wed Feb 18, 2009 2:51 pm
by Snelvuur
maybe nice to put it online for other to see..
and dont forget to keep it in english
(i make the same mistake now and then too)
Posted: Wed Feb 18, 2009 3:10 pm
by stefxx
Whoops, English, you're right.
Can I attach it to this thread or upload it somewhere here? It is about 400kb...
Posted: Wed Feb 18, 2009 5:23 pm
by TANE
upload here is max 200 kb
You can send the file to Snelvuur or to me for upload to another place.
Posted: Wed Feb 18, 2009 5:44 pm
by Snelvuur
On the topic of the site you can see a "files" link, Chak or me or pieter can put it there (has 100mb limit per file)
Posted: Wed Feb 18, 2009 10:02 pm
by TANE
Pronto interface/scripting what is developed by sddroog
This config file is for the Pronto TSU 9400 but can easly be converted to TSU 9600
Basic functions for Homeseer control with two way communication.
DeviceOn
Deviceoff
DeviceDim
DeviceBright
DeviceEvent
http://files.binkey.nl/Pronto/Modules/H ... motica.xcf
