Streaming IP Camera on the Pronto incl Pan&Tilt
I've got it, i've got it! Camera on the Pronto including Pan&Tilt.
Will put a link to a movie here later.[8D][8D]
- Snelvuur
For which camera is that? Xcf?
It's for a Sony EVI-D30 in combination with a Convision V200 videoserver.
Pan&Tilt is done by HTTP -> HA app -> RFXCOM LAN Intf + Serial module -> Camera VISCA interface.
Here's the movie: http://www.hekkers.net/files/Pronto_IP_Camera.wmv
- Snelvuur
and xcf file? Good work btw, it looks nice.
It's the IP Camera.xcf for the Panasonic, with some very small modifications. I'll make a reply later to point out where i had to make changes, so you know where to look to adapt this xcf to your own hardware.
- Snelvuur
Thats the magic words i wanted to know i did try to modify it for an axis 241q. But changing the ip, and the jpg settings didn't work enough yet. I did order Flannagans javascript book (5th edition is now availible on bol.com)
Btw, i placed the wmv at youtube for easy clicking. (mostly since i have a problem with the wmv files it seems)
Here a little summary on how i got the IP Camera.xcf running.
First i'll show the original line, the next line is what i made of it.
Basically i had to change to commands to move the camera to the ones i use.
Changed the action-URL to the one i use.
Changed the GET for retrieving a JPEG image from the camera.
Changed these 2 lines to extract the bitmap data from the camera response to the GET.
Added an extra line to initialize the data variable. Not necessary, but is better IMO.
The original XCF is using the same IP for getting the JPEG images and sending commands for Pan&Tilt. I use 2 different IPs: 1 to access the camera and another for commands (Pan&Tilt). So i added the latter one the hard way.
That's all folks... i hope you have fun with it and are able to get your cameras showing on the Pronto with this.
One more tip; don't edit in the PEP Editor; take a text editor with syntax highlighting and other handy features (i use UltraEdit), copy the script to your favorite editor, edit there, and paste it back when your done. With larger scripts as this one is, the PEP Editor window is to small to work with in a comfortable way.
Line
57 var MOVE_HOME = "HomePosition";
var MOVE_HOME = "pos=home";
58 var MOVE_UP = "TiltUp";
var MOVE_UP = "tiltrel=up";
59 var MOVE_DOWN = "TiltDown";
var MOVE_DOWN = "tiltrel=down";
60 var MOVE_LEFT = "PanLeft";
var MOVE_LEFT = "panrel=left";
61 var MOVE_RIGHT = "PanRight";
var MOVE_RIGHT = "panrel=right";
756 var action = "nphControlCamera?Direction=" + direction + "&Mode=Motion&Resolution=" + currentResolu....
var action = "camcontrol?camera=1&"+direction;
762 var bitmapHTTPGet = "GET /SnapshotJPEG?Resolution=" + currentResolution + "&Quality=standard&Interv....
var bitmapHTTPGet = "GET /fullsize.jpg?camera=1 HTTP/1.1\n\n";
804 var imageStartIndex = this.data.indexOf("jpeg");
805 var bitmapData = this.data.substring(imageStartIndex+8);
var imageStartIndex = this.data.indexOf("\r\n\r\n");
var bitmapData = this.data.substring(imageStartIndex+4);
890 var HTTPActionCommand = "GET /" + action + " HTTP/1.0\n\n"
var HTTPActionCommand = "GET /" + action + " HTTP/1.1\r\n\r\n"
actionSocket.data = "";
912 actionSocket.connect(cameraList[currentCameraNr].IP,cameraList[currentCameraNr].port, CONNECT
actionSocket.connect("192.168.10.6", 8000, CONNECTION_TIMEOUT);
This is image mode of my Cam...can I get this one on the pronto?
There is also java mode
page's are from custom IP video server 9100A
<html>
<body>
<table border=0 width="100%">
<tbody>
<tr><td valign=top>
<font size=2>
<nobr><a href="home.htm?APL">Java Applet Mode</a></nobr><br>
<nobr><a href="home.htm?IMG">Image Mode</a></nobr><br>
</font>
</td><td>
<script>
if (navigator.appName.toUpperCase() == 'MICROSOFT INTERNET EXPLORER') iBrowser = 0;
else if (navigator.appName.toUpperCase() == 'NETSCAPE') iBrowser = 1;
else if (navigator.appName.toUpperCase() == 'KONQUEROR') iBrowser = 2;
else iBrowser = 3;
fVer = parseFloat(navigator.appVersion);
function StartCamera(o, n)
if (o.readyState == 4)
o.URL = location.protocol + "//" + location.host;
if (n == 2)
o.Images = 1;
o.Start("Download");
var sChoice = (location.search + "").substr(1);
if (sChoice != "ATV" && sChoice != "IMG" && sChoice != "APL")
if (iBrowser == 0 && navigator.platform.toUpperCase() == "WIN32")
sChoice = "ATV";
else if (iBrowser == 1 && fVer >= 5.0)
sChoice = "IMG";
else
sChoice = "APL";
if (sChoice == "IMG")
document.write('<font color=green size=2>Image Mode</font><br><IMG SRC="/GetData.cgi" >');
else
document.write('<font color=green size=2>Java Applet Mode</font><br><applet codebase = "." code="WebCamSimpleViewer.class" archive = "core.jar" width=650 height=550></applet>');
</script>
</td></tr>
</tbody>
</table>
</body>
</html>
Maybe it's better you send all the documentation you have and i'll have a look.
- Snelvuur
Chak, if your cam is not PTZ just change the things in digits example. I allready got my first cam streaming. No PTZ yet, but that should not be to hard.
Only issue i have is that the axis 241q has 4 inputs. So how can i put in 4 camera's on the same ip.
Look at the Parameter pages! That's where you can enter all the IPs.
- Snelvuur
Yes, ip's so i have 4x the same ip. So how does it know the difference? (allready have an idea perhaps on how to do it) i could use in the name say "Outside [1]" then strip the name so i have "1" then add this to the url.
Then the cam number is probably a parameter in the command on line 762.
- Snelvuur
Thats correct, i'll try and put something in there then too.
