rss wordwrap somewhere else
Forum about hardware/software for the Philips Pronto TSU9600 and other remotes.
Postby Snelvuur » Sun Jan 27, 2008 5:57 pm
I tried to use the wordwrap function in my own pages, but whats wrong. I still get the normal "long" line instead of one wordwrapped.
Anyone has a hint? :-)
var start = 0;
var result = "";
var socket = new TCPSocket(false);
var t1,t2,t3,t4,t5
var event1,event2;
var descrip1, descrip2;
var tijd1;
var d;
String.prototype.wordWrap = function(m, b, c){
   var i, j, s, r = this.split("\n");
   if(m > 0) for(i in r){
      for(s = r[i], r[i] = ""; s.length > m;
         j = c ? m : (j = s.substr(0, m).match(/\S*$/)).input.length - j[0].length
         || m,
         r[i] += s.substr(0, j) + ((s = s.substr(j)).length ? b : "")
      r[i] += s;
   return r.join("\n");
String.prototype.trim = function() {
   return this.replace(/^\s+|\s+$/g,"");
socket.onConnect = function()
  socket.write("GET /cgi-bin/channelinfo HTTP/1.1\r\n");
  socket.write("Accept: */*\r\n");
  socket.write("Host: 192.168.1.99\r\n");
  socket.write("\r\n");
socket.onData = function()
  result += socket.read(5000,1000);
t1 = result.indexOf("class=\"event\">", 0)+14;
t2 = result.indexOf("/span>",t1)-1;
event1 = result.substring(t1,t2);
t4 = result.indexOf("class=\"description\">", t2)+20;
t5 = result.indexOf("/span>",t4)-1;
descrip1 = result.substring(t4,t5);
// CF.widget("storyline").label=descrip1;
var newtext = descrip1.wordWrap(30, "\n", false).trim().split("\n");
CF.widget("storyline").label=newtext;
socket.onClose = function()
socket.onIOError = function(e)
if(socket.connected == false)
  socket.connect('192.168.1.99', 80, 3000);
Snelvuur
Postby Digit » Sun Jan 27, 2008 6:36 pm
Could it be spaces are still "&nbsp"?
Since you don't seem to use the StripHtml().
Your descrip1 could look like 1 big word to the wordwrap function and will not be split.
Postby Snelvuur » Sun Jan 27, 2008 10:21 pm
Well i do know (i think you) or someone else pointed out a wordwrap too. But i cant remember where it is, remotecentral, mail, im, forum.. too much stuff these days.. trying to put it all in my head :)
Snelvuur
Postby Digit » Sun Jan 27, 2008 10:27 pm
This is the only other topic where wordwrap is involved:
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=673.
But that's the RSS feed topic, and you're using parts of code right now, so it must have been someone else. Now you mention it, i read something about wordwrap on remotecentral, about a month ago i think.
Postby Snelvuur » Sun Jan 27, 2008 10:29 pm
Yes, but that was wordwrap for only the end of the line, not words i think.
Snelvuur
Postby Digit » Sun Jan 27, 2008 10:36 pm
Could be.
How about my questions? Did you have a look at that?
Did you have a very-very good look at the descrip1 variable before the call of Wordwrap?
A CR+LF at the wrong place in the string can let the Indexof-calls perform different from what you'd expect; i had that problem once; took me 2 hours to find out.
Postby Snelvuur » Mon Jan 28, 2008 7:26 am
I used a simple wrap, that only cut the lines at a certain amount of characters. That did work with my descrip1. Dont know how else to check that.
Snelvuur
Return to Philips Pronto (TSU9600), IRtrans and other remotes
