New HTC touch Blackstone
Moderator: TANE
http://pdadb.net/index.php?m=specs&id=1469
http://tweakers.net/nieuws/55648/specif ... n-uit.html
Let's hope this one has a better performace then all the other HTC phones with Windows Mobile. Until now its a real pain in the a....
Datasheet_State: Preliminary specifications
Expected_Release-Date: December, 2008
Project-Codename: HTC Blackstone
Browse all devices under HTC Blackstone codename
Dimensions: 62.8 x 115 x 12 millimetres
Software_Environment
Operating:System: Microsoft Windows Mobile 6.1 Professional
Browse devices running this OS
Microprocessor,+Chipset
CPU: 32bit Qualcomm MSM7201A
Browse devices based on this microprocessor
CPU-Clock: 528 MHz
Memory,_Storage;capacity
ROM-capacity: 512 MiB (accessible: 327.2 MiB)
RAM+capacity: 288 MiB
Display
Display+Type: color transflective TFT , 65536 scales
Display-Diagonal: 4 "
Display_Resolution: 480 x 800
Sound
Microphone(s): mono
Loadspeaker(s): stereo
Audio:Output: 3.5mm
Cel****ar-Phone
Cel****ar:Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS900, UMTS2100
Cel****ar-Data_Links: CSD, GPRS, EDGE, UMTS, HSDPA
Call_Alert: 40 -chord melody
Vibrating;Alert: Supported
Speakerphone-: Supported
Control+Peripherals
Positioning;Device: Touchscreen
Primary:Keyboard: Not supported
Directional:Pad: Not supported
Scroll_Wheel: Not supported
Interfaces
Expansion;Slots: microSD, microSDHC, TransFlash, SDIO
USB: USB 2.0 client, 480Mbit/s
mini-USB
Bluetooth: Bluetooth 2.0 + EDR
Wireless-LAN: 802.11b, 802.11g
Infrared_Gate: Not supported
Multimedia+Telecommunication
Analog:Radio;Receiver: FM radio (87.5-108MHz) with RDS
Digital-Media_Broadcast;Tuner: Not supported
Satellite;Navigation
Built-in;GPS+module: Supported
Complementary-GPS+Services: Assisted GPS, QuickGPS
Built-in_Digital-Camera
Main;Camera: 4.9 MP
Autofocus;(AF): Supported
Optical_Zoom: 1 x
Secondary+Camera: 0.3 MP
Additional-Details
Built-in:accelerometer: Supported
Battery: removable
Battery-Capacity: 1350 mAh
my next device..
Looks nice, and it's even beter than the iPhone
(video is with Dutch subtitles if needed)
[youtube]eisadEADpwk[/youtube]
<h6>Anyone interested in time travel meet me here last Thursday!!</h6>
[ status banner ff off-line i.v.m. server updates.]
Nice device...can't wait..
Yesterday my new HTC HD device is delivered. With two other new devices (S740 and the G3)
WOW what a device
Screen is amazing
Not all the applications can handle this new screen size.
Most common will work fine.
RDP
TomTom 7
Build in Opera 9.5
there is a kind of feedback build in ..when you touch the screen there will be short vibration
Screen size is comparable to the TomTom navigation devices..but with higher resulution...this means more details.
only missing part is flash...hope this will be available soon.
WOW what a device
Screen is amazing
RDP
TomTom 7
Build in Opera 9.5
Chak, of friend of mine has one. He needs to control live security cams that work using a java application, there's a black box instead of images as seen with pc. so not 100% java support ! do you suggest some tricks?
java or activex?
@drmacchi
there are actually different virtual java machines on the ppc platform, so just try another and see or that one works.
I cant tell wich one is going to work, but have a look on a site like xda-developers.com and search on "virtual java machine"
@andy : it's java (?) in pc mode it ask you to install an activex plugin and then i have java platform running in taskbar
maybe if you give the brand and name of camera it would be more useful.
The camera is chinese, it's the one of this topic:
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2113
Java will not work on most of the mobile devices.
Check if there is support for RTSP or 3GPP
if yes
You can tray two application's
ViewCommander or CorePlayer.
Other option is HSTouch for this you need still image support
if yes
