Belkin Lan USB HUB
Forum about Domotica related gadget like Pocketpc, UMPC, Smartphones, Ipad Etc
Moderator: TANE
Belkin Lan USB HUB
I can't find the power adapter of the Balkin USB Lan...so much adapters an so much..connectors....and almost sure i have used for something else.
Can some please make a picture of the adapter and the connectors..
Belkin Lan USB HUB
Sorry Chak no photo at this time of day, but my power supply mentions Asian Power Supply Model No:DA-24F12 (and a lot of Chinese characters). The adapter contains a cable to plug it into a power outlet (so no outlet connectors on the adapter itself).
Belkin Lan USB HUB
Rene,
Thanks for the info
Found the adapter only ..without the plug..(cable for in the Belkin)
I have removed this one..for usage somewhere else...
I have connected some standard ones...they don't work..can you please make picture of the plug?
Belkin Lan USB HUB
I do not understand what you are talking about. The plug that goes into the Belkin is hardwired to the adapter, I cannot unplug it from the adapter. Did you cut it? See picture (sorry for the quality, it is made with my iPhone).
Belkin Lan USB HUB
Rene..
connector is not connector..i have cut it.
Found it..but it's not working...:(
not sure what the problem is...there is power on the connector.
Belkin Lan USB HUB
Swapped + and - ?
Belkin Lan USB HUB
hmmm inside is +...or belkin must using them different.
on the adapter is also inside plus.
can you confirm that?
Belkin Lan USB HUB
Yes, + = inside is correct...
Belkin Lan USB HUB
compliments for Belkin
They send me a new one.
old one was really really broken..:)
Noel
Re: Belkin Lan USB HUB
Post by Noel »
Anyone here who might know how to set Windows 7 to wait for the Belkin Lan USB HUB to disconnect all "USB" connections before Windows 7 shuts down?
Problem now is that Windows 7 just shuts down, and when booting up again giving me an "error" about not shutting down correct.
Return to “Gadgets Forum”
